XR200 Running problem after warm
Hey guys it's been a while since my last post and i just had a few questions. I have an 85 XR200R I really want to get my bike in reliable running/starting shape to really get out to the trails. It starts easy enough, and runs like a champ, but after riding about 20 mins around the neighborhood and i shut it off it will not re-start and gas seems to be leaking from somewhere in the engine. (Seems to be a flooding issue?) not sure. ive been tinkering with the air/fuel mixture screw and it makes such a difference riding but doesnt help with this re-starting when warm issue. Any help is greatly greatly appreciated.
thanks guys! :thumbsup:
Justin
Also, spark plug was sooty black after pulling it out. thought this might help. thanks guys!
check the carbs tank needle, it might be getting stuck (with any sort of dirt or old dirt gas), flodding the carb.
Your carb needs to be cleaned and serviced. If you can not do it , find someone who can.
i pulled the carbs apart about 2 months ago and doused everything in carb cleaner, everything was clean for the most part
i do think getting them serviced would be a good idea though. i prefer to do the work myself but when it comes to rebuilding the carbs id like to have someone with the expertise do it. anyone know how much this would cost? maybe a ballpark figure
It's not enough to just clean them. You need to make sure the float levels are right too. If they're set too high you get a rich/flooding condition.
They also need to be synchronized.
ok that makes sense. is setting the float levels and stuff including in a normal carb rebuild service? or would i have to specifically ask them to do that as well? thanks for the help guys
It should be a part of a rebuild, but don't take anything for granted when having someone else do work for you. Ask specific questions. Find out what exactly they plan on doing as a part of their "service". Voice your concerns and make sure they address them.
ok thanks so much ill look around tomorrow and get some prices. always helps to be an informed customer. really appreciate it guys thanks for the input!
  • Similar Content
    • By 661Bran28den661
      What’s up guys. Totally new here picked up an XR400R I live in the desert so I’m riding often and enjoy it. But I am having some issues with my  01 XR400R. I brought it out this morning for a putt and it seems to be choking up in the top of second. Like a bog an go bog an go. First seemed fine and third I didn’t make it high enough into the rpms to see. Before I brought it back to the garage. Yesterday I also changed the air filter back to an uni. I had seen the other one had a hole in it and the box was dirty gunned up and oily. I removed the airbox gave it a good clean out wiped everything down very well put a piece of screen over the snorkel Or where it used to be I should say. “Lightly oiled the filter.Also the spark arrester an tip for the bike it did not come with I ended up making one with a piece of flat steel and drilling holes. Whilst doing this. I found also a crack in the pipe. It almost sounds as like there’s a vacuuming or whistle? When revving.The first one I had made worked fine I had no issues. This one I am wondering maybe if it’s a cause of a little too much back pressure.So I’m assuming it’s either a Carb or exhaust problem. Or something that could totally be minuscule. Or major issue. Would definitely like some second opinions and any advice would be greatly appreciated. Thanks guys!
      TWISTIN THROTTLES & CRACKN BOTTLES
    • By ddickinson
      My lanky 14 year old boy started showing an interest in riding MX/Off-Road so I sourced the best beginner friendly, yet dirt worthy, bike I could find: an Ol' Honda XR250R (2004). So far I've replaced a few clutch levers and perches with stock parts. That's gotten old and I'm looking to upgrade to an ASV or Torc1 type fold-able clutch/perch brake combo. Went to purchase online today and to my surprise there were no such parts listed for the XRs. I saw plenty of CRF/CRF-X choices and they seem to differ depending on generation. Obviously I can use nearly any perch/clutch combo as long as the two match; but I was wondering if anyone knew which of these levers was closest to stock? Also, will the first gen CRF250X brake lever work on the XR? These may be stupid questions to some; but I'd rather ask a dumb question than drop money on an ASV brake lever I can't use. Thanks for any help.
      #xr250r#hondaxr
    • By TheLastByte
      Im currently in the market for an xr400r, and considering buying one that's had some heavy engine work done. The current owner claims to have bought it from a friend who's an XR enthusiast. The PO installed a big bore kit and high comp piston, as well as a xrs only pumper carb, rsw triple clamp, aftermarket clutch, street lights, and a whole bunch of bling.
      My main concern is the effect the upgrades will have on the engine's longevity. How much quicker will I be going through top ends with the setup on this bike as opposed to a stock setup, and should I be worrying at all about bottom end longevity as well? I wouldn't mind having to eventually redo the top end, but I don't want to deal with a race bike type top end rebuild schedule on an XR.
      Is there anyone here who's running a bike similar to this one who can give some advice?
    • By Ralph303
      I have a 2001 Honda XR400R. It has a whirring/grinding sound in the lower end and a vibration in the top end. I pulled the valve cover and everything looks good. Decompression lever looks to be in order. Anyone know where I should start looking or just rebuild the whole engine. Ballin on a budget, but really love this bike. It looks like it’s new otherwise. Oil was jet black and thin. Thanks in advance!
    • By junglePIG
      Hi, I have an Xr250r with a buckled/ wobbling front wheel, after trying to true the rim i have broken a spoke.
      I am wondering if it is possible to lace any 36 hole aftermarket rim to the oem hub, also will i need to buy an xr250r specific spoke set. also could i take a 36 hole rim from another front wheel and lace that up???? thanks
