changing 2007 TTR125LE oil?
hi, im going to change the oil in my ttr125le this weekend and i dont know what or how much oil to use. i do not have the manual so i cant refer to that for help. also, when you change the oil is that all you have to do? no filters or anything? any help would be appreciated, thanks
-tyler
no filter just a screen, make sure it is clean. I always buy oil in the larger containers. just fill to the dipstick. Run it and checkit again.
Its like 1.06 qts So just drain the oil and pour in a quart and call it a day. The screen isnt a inspect every oil change thing. Ive never checked mine.
You can download yamaha manuals here: http://www.yamahaownershandbook.com.au/?r=0
They are really good and basically a full shop manual.
You don't want to start another discussion on which oil! Just make sure it is good oil and you change it often. Don't use anything that will not work with a wet clutch, like any moly additives. Don't use anything that says "energy conserving". All you ever wanted to know about oils and oils for motorcycles: http://www.calsci.com/motorcycleinfo/Oils1.html
