Gnarly/Fatty
I have a 09 YZ250 and basically ride trails, I've got people telling me that a FMF Fatty will increase my low end but I thought that's what the Gnarly is for. Any comments.
Eh, http://www.thumpertalk.com/forum/showthread.php?t=344959
But seriously. The fatty's supposed to be a great overall pipe. From a 07 stock pipe to a Gnarly I noticed increased torque/pull but not a night/day change if you will. There is less top end with the Gnarly no doubt. This matters not because I never use it.
The Gnarly is gnarly man. Hit a big rock and laugh your way home. What would taco a fatty or stocker will just give you a nice scrape on the Gnarly instead. Very durable pipe. Pipe guards don't work IMO. :thumbsup:
I run a gnarly on my KTM, I ride single track and tight stuff only. The gnarly makes the top end really flat..if you ride mid to faster stuff the fatty is the way to go.
I went from a complete Doma System with the Doma shorty exhaust to a Fatty with the Q Stealth,I noticed my low end was just slightly weaker but my over rev was really extended. Comparing the 2, if Im going jumping at a track with alot of short run ups Im going to use the Doma system but if any longer runs appear the fatty and Q stealth go on
The Gnarly is gnarly man. Hit a big rock and laugh your way home. What would taco a fatty or stocker will just give you a nice scrape on the Gnarly instead. Very durable pipe. Pipe guards don't work IMO. :ride:
Yeah, it was my understanding that the Gnarly is a thicker pipe and more for the low end grunt but this local bike mechanic (reputable) is telling me I'd benefit more from the Fatty.:thumbsup:
If you get a magnifying glass and correlate Stimps' text entries to the dyno charts you will see that his factory fatty (no different than regular 'cept for metal finish) did very well. IMO, it's an MX pipe.
I'd go with the Gnarly, but thats just me, it defintely takes away the topend but mine was much stronger off the bottom and into the mid which is generally where i like to ride.
Just depends on how you like to ride your bike, if you like carrying higher rpms you won't like the Gnarly, and last i knew Mark you liked to twist the throttle and keep it spooled up
Edited by yathump
I got a gnarly on my 06, and I noticed a decent low and mid boost. The pull comes on a bit lower, but signs off a little sooner. Since I ride trail and single track it works really good for me. The insane hit is still there, just a little lower. I love the hit and if the pipe change had dimished it I would have removed and returned the pipe same day. Plus as previously said, the pipe is tough. I have banged it several times and not even a dent or scratch. That is what keeps that pipe on the bike. Once I got the Gnarly, I rejetted to get rid of spooge, and while it is just ever so slightly rich it pulls like a 4 stroke. And plug fouling issues went away too!!!!
I just bought a 00 YZ250 that ai'm setting up as a Harescrambles bike. It has a nice shiney FMF pipe on it, but i don't know which one. ( fatty, gnarley or whatever) Any way to tell?
Buy the Gnarly if you want mega low-mid power. Turns the YZ into a low revving tractor. But the only drawback is the lack of top end. If that's not a worry for then buy it.
Supercross guys used to use Gnarly pipes for the bursty power in tight confines.
A friend of mine swears by them. I should hook a ride on his bike to see if I like them in the woods. I haven't tried one since 1994 and that was only for a short ride. At the time I thought it was too bursty for the woods. But a lot has changed since that time.
About five or ten pounds, just a little, none, what were we talking about?
Stop whining and PM me your email address and I'll send you some bigger ones. I used to have eyesight like that once until I got a few different hobbies..LOL:thumbsup:
You know the joke.... a magnifying glass and some tweezers.... :thumbsup:
PM almost sent!
True Gary, I do tend to wring it out but you know how some of those sections of tighter trail are, not always room to get on the gas that much. I'm having the bike rejetted again and was considering a new pipe with the jetting, not sure about sacrificing the top of the RPM range though.
The combo of a new pilot and the Gnarly makes my bike scary fast off idle all the way to mid. If I'm not careful with my throttle jumps over logs, I can loop out pretty easily. Love it!
And you will definitely lose the top rpms
There was someone on here that bought a DEP the enduro version or whatever they called it, that may be a way to go also since everyone says the DEP gives a boost everywhere
Well i thought they had an enduro version but i couldn't find it
http://www.deppipes.com/#/yamaha/yz250/
