cams
You won't notice the difference between stage 1 HotCams and E cams....they are almost identical. If you want more bottom end you can run the E intake or Hotcam intake with your S exhaust cam...if you want more top end run both E cams or both Hotcams. The beauty of the E cams is that they are cheap and available to buy used ($100 or so for a set) and worth it....plus the E cams will drop right in without reshimming.... if the S cams you are replacing are shimmed properly and valve clearance ok then the adjustment will stay the same without reshimming 99% of the time. I say buy a set of E cams and try it with the intake only....if you like it...cool. You can always put the exhaust cam in later if you feel like a change in your power band.
Another diff:
E cams dont have adjustable sprockets.
Hotcams do.
E cams have a slightly 'better' profile.
Both are fine for stock bore and 94mm bigbore.
If you can get a set , the E cams will be the much cheaper option , as much as up to a third of the price by what has been said on here . I put the hotcams intake and exhaust in my standard motor , and there was a notable difference between standard and cammed . The bike has a lot more low down grunt and will power wheelie in first and sometimes second [ this is with an FCR/MX also ] . It now revs a lot harder higher up in the rev range aswell . It seemed to used to run out of puff at a certain point , it was still revving but it wasnt pulling . Now it is pulling right into the higher rpms , greg
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
