Crank compatibility 02' to 03' & up??
Can I use a later model crank in my 2002 if I change the flywheel? A friend has a late model new crank he will give me. But I have an 02'. I don't think the clutch side is different. Are the cases the same? Any insight would be extremely helpful. Thanks in advance!
cases are the same, flywheel side of the crank has a fatter taper. off the top of my head I cant remember if the primary gear is different or not.
I'll check out the primary. Thanks for that info:thumbsup:
Crank diameter is larger on the 03 so you'd need a new FW like you noted. Other than that, it should bolt up.
That's what I wanted to hear. Do you think there would be any issue with the stator?
