Quiet performance?
Looking for a performance pipe that is not to loud. The motor is stock with the BBR air filter.:thumbsup:
Based off of all of the threads on all the forums I have read regarding this, the Pro Circuit T-4 exhaust is the way to go for a stock motor. That's what I plan on getting after I get my suspension done.
I just put an FMF on my son's 110. It is much deeper sounding but not that loud. It's not nearly as loud as my Pitster Pro X4's stock exhaust.
If you are looking for quiet then the stock pipe with the header washer drilled and the baffle drilled is the way to go. Keeps all the low end and is still pretty quiet.
For aftermarket I have BBR with the quiet core insert on a stocker. The pipe is fairly quiet and runs pretty well. This is the older style not the D2 pipe with the larger header pipe. The nice part about the BBR pipe is we use the quiet insert for trail riding and can remove it when at private tracks.
I also have a CHM pipe on one that is WAY WAY too loud but runs better than the BBR pipe bike.
Good luck
