YZ80 float setting/Jetting problems
Recently purchased this bike and it runs good with exception to a low end stumble.
Problems noticed when I first pruchased it:
1) Sporatic idle (idle speed would go up and down)
2) Ran choppy going thru 1/4 to 1/2 throttle
3) Fuel dripping from float bowl vent tube after sitting for 10 - 15 minutes. (engine off)
Note: Performs well at high RPM w/ plenty of power.
Adjustments made since:
1) Thoroughly cleaned the carb ( but it appeared clean prior)
2) Adjusted the Needle Valve to top clip setting ( lowered the valve to the max)
3) Adjusted the float tab upward (note I don't know the spec, so i played it by ear)
Perfomance after the above adjustments:
1) Not near as choppy at low RPM, but still has a slight stumble at 1/4 throttle as I casually cycle thru each gear.
2) Idle is much more stable
3) Fuel still drips from float bowl vent tube after sitting 10 min ( but appears to be less before)
4) Still performs well at high RPM
Question:
Based on the above info, how can I remedy the stumble at low RPM and stop the fuel drippage ?
I replaced the need valve.
Replacing the need valve stopped the fuel drippage, and corrected the low stumble.
It now idles perfect and runs great low RPM.
