Drz leaking something
Saw this morning there is something leaking from the left side of the motor, just above the gear lever where something attaches with like 3 screws.
No pics, plz yelp!
Should not be too hard to figure it out considering there are only three kinds of liquid that run through an engine. Oil, fuel, and antifreeze. Is it green/blue or is it oily? Pictures would also help. It's hard for someone to give you help when your talking about where something attaches with like three screws.
Its oily, it runs down from the 3screws to the allen key bolt attached to the fly wheel. Its only slightly leaking though
your leaking oil from the stater clutch cover. get a gasket and some blue locktite for it and replace it.
its easy to do. just remove the 3 screws tap off the cover. remove the old gasket and clean the 2 surfaces the gasket sits on. put the cover with new gasket on put a drop of blue locktite on each screw and tighten the 3 screws. Don't over tighten them. just snug them down with 2 fingers. if it still leaks just tighten the screws a little more. No big deal.
