Yz465h - 1981
Hi there,
Anyone knows what the sizes and numbers are for the swing arm bearings?
For that matter also for the steering stem
Regards
Nic
They're listed in Ebay from a couple companies, one of them is all balls. Way cheaper there. By the way if you need main bearings, Applied.com is a national chain bearing house. You need #6306 in any brand and you will save $10-$15 per bearing. If you could get your swing arm bearings out they could probably size them for you.
