Should I change the oil by the odometer? Or install an hour meter?
Im just about to get an hour meter installed on my new to me 08 450x before I pick it up. I think I'd better.
I was told I should change the oil in the engine every 500km's - 310 miles.
& change the oil in the gear box every 1000km's - 610 miles.
What do you think about that?
I think I'd prefer to change the oil by hours not km's. Because most of the time it will be at low speed but highish revs. The Odometer is kinda irrelevant really.
I'm no moto x rider. More like a trail rider.
If i was to service it via the hour meter, how often should I change the oil in both?
Every 10 hours for the engine? & 20 for the gearbox? That's what the parts guy at the dealer said he does on his moto x 450. But for me as a trail rider maybe I should not do it so often?
& those of you who have installed an hour meter. Where is a good place to mount it?
Cheers!!! :thumbsup:
I change the oil every 1000 kms, both sides, and the oil filter too. The x's has 10000 km and it runs great. :thumbsup:
personally i think the odometer is better than an hour meter. Why... Its how all motor vehicles, in particular the higher priced ones measure durations. Is an hour at standstill the same as an hour of riding. No. Hour meters are great for keeping as little weight on the bike but providing the ability to take usage measurements. But, odometer is definitely preferred over an hour meter.
When in doubt, change it out.
All of this is assuming you have dumped the OEM piece of crap odometer for something more accurate. (I use the trail tech vapor)
1 km cruising at low RPM isn't the same as 1 km at race speed either.
An hour meter is a far more accurate representation of 'run time' on the motor which, when it comes to oil, is really what matters isn't it? Case in point, your odometer is going to log distance even when the bike is moved around, coasting with the motor off, etc...
All the cumulative time the bike remains stationary, but with the motor running is relevant. That's why farm equipment and diesel trucks use hour meters - they accumulate a lot of run time when they're not moving or just creeping a long.
If I'm not mistaken, a lot of the onboard computer systems in cars base oil change intervals on run time, not distance.
Depending on your riding style, you can definitely get away with basing maintenance intervals on distance, rather than run time. I don't think there's anything particularly wrong with that.
I just happen to believe an hour meter is a far more accurate tool and I like accurate tools.
Yes indeed.
I go by the hour meter and mounted mine on the right side of the frame by the ID tag with dual sided 3M tape:ride:
All interesting comments and viewpoints.
If we get into the minutiae of distance rolled after a flame-out, etc., then... :thumbsup:
But consider this in the mix. Riding conditions: Particulates/dust in the air, altitude, temperature, which gears you mainly rode in, cargo/rider weight, etc.
500KM for my bike might equate to 150KM for yours, or vice versa, etc. Or seeing exactly 5.0 hours and needing to change the oil right away is still an arbitrary metric unless other factors are all included.
Hour meters are inexpensive. Not a bad option to have. But, I say keep your head in the assessment as much as you can to make the final determination of change intervals...add up the mileage, how the bike was ridden, and time, and go from there.
One thing to absotively posolutely keep in mind in ALL oil threads: If you haven't sent your oil off for analysis to get the Real State of your oil, then you are missing most of the information you need.
http://www.blackstone-labs.com/
How much mileage do you think you put on your bike without the engine running? I really don't understand this point as your talking maybe an error rate of 5-10 miles out of 300 miles of riding.
We aren't talking diesels engines. There is a big difference in stationary time on diesels trucks or farm equipment compared to a bike's engine. You won't have the X stationary and running for more then 5 minutes or you'll overheat. Diesels run for hours in a stationary state.
I think we are saying the same things but on different sides of the fence. Both odometer or hour meter will have a certain degree of error but provide an estimate to time or mileage so that it can give the driver a benchmark on when to conduct maintenance intervals. The error rate can be determined based on the type of riding or conditions experienced. When in doubt, change it out.
The x's odo only goes up to 100 miles. Unless your really good about logging miles an hourmeter is far more practical.
Yes, I agree actual miles ridden and conditions are also a factor in me deciding when to change my oil, it's just the hourmeter helps make it more manageable. Especially when you are maintaning bikes not ridden by yourself (think kids, un-mechanical friends....ect)
Agreed, the first thing that needs to go on the X is the crappy odo. The yamaha WR comes with a very nice digital odo. I do not understand why honda puts something so cheap and inaccurate on such a great bike.
Like I said - I'm just going for accuracy. The point is run time, not distance when it comes to oil life. You simply can't deny that run time is a better, more accurate metric than distance when it comes to the life of oil.
Run time at least is a better baseline metric than distance. You certainly have to factor in all the other variables that phuzz up there pointed out. For example, I always change my oil immediately after a desert race, which is usually only a 2-3 hours of run time. Whereas I'll go 10 hours between oil changes if I'm just out play riding.
If you really wanted to get accurate, the new EFI bikes come with onboard computers capable of tracking hundreds of data points. The new Highland bikes, for example, log something like 200 different variables so you can plug it into a computer and it will tell you everything that has happened with the motor up to that point. You could then make accurate calculations on oil life based on temperatures, pressures, etc...
http://www.ushighland.com/
I could argue the merits of using an hour meter over an odometer all day long, but the bottom line is you need to keep track of something - distance or run time - and perform routine engine maintenance at regular intervals.
Besides, I like to flat track corners and spin the rear tire a lot, so my rear tire is certainly traveling farther than my front at times :thumbsup:
You can see what the engine oil looks like thru the view window and I take that in consideration, but on the tranny side you can't see what all that clutch slippage and gear shifting is doing in the tightstuff even if you are not riding fast, meaning low miles. You can contaminate that oil pretty guick in some good grarly dusty single track so I take all 3 things in consideration, If I'm doing a lot of d/s with a lot of payment and low dust I'll go a lot further than between changes than if doing the tight dusty singletrack. I usually compare with my airfilter too to see how it compares and go from there
I find the stock odo to be quite adequate.
Well this is a battle for advise. There are a hundred opinions. I personally use the OEM odometer. When I hit 100 miles it is time for an oil change. I ride strictly trails and have found this to work good for me. The oil does not look to bad when it comes out.
As for the oil analysis being sent in. Does anyone have the reports that came back on this? If so what was it and how much time or miles were on the oil. I think this would be great to find out if my schedule is to early or to late. Just do not have the cash to do it now.
Some guys will tell you to change your oil every 3 hours and the shop will tell you to wait much longer. It is realy up to you to read the hundreds of posts and make a determination out of this information. 100 miles works for me.
good luck to you in the search.
Hours is a better indicator.
I ride in 2nd and 3rd gear all the time in the woods, rarely seeing 25 mph. If I was in 5th gear doing 50 mph, I'd go twice the distance even though the engine is doing the same amount of work (rpms). Does this mean I can go twice as long between oil changes if I only ride in 3rd gear?
See where the inaccuracy in the distance method is? That can lead some people to believe they can run their oil 2X longer and possibly do engine damage.
My riding style is more gentle than the desert guys also. And it's not quite as dusty in the woods. So I can go a little longer for those reasons too.
buy a trail tech they record both hours and miles!!! Me I go the mileage route as Ive ridden 6 hours and only went 60 miles which equals 10 mph on some of the tree dodging excursions in MI. Either way works its just what you feel more comfortable with, everyone will have there own opinion on this subject as you can see!!
you could get real fancy and base it off the amount of fuel used. thats how bmw cars base their service interval.
Hour meters make things sooooo much easier. Good points by crfxer in that you can't always rely on time or distance to figure out if you need to change the oil or not.
Yep ok thanks guys I will definitely get an hour meter fitted. :ride:
But, how many hours before a service? 10?
:thumbsup:
In Oz, the X comes with a nice big digital speedo/odometer! Its got all the info on it that any street bike would have. Even a lap timer!
What do youse get? Just an analog Odometer?.... Oh weak.
:thumbsup:
  • Similar Content
    • By mikesbaron
      2005 CRF450X:
      Stalled my bike on an uphill single track, tried to start it and it would not start. Pushed it off the mountain solo (took me 3+ hrs to cover 3.5 miles!). At home tried spark plug to frame to see if I get a spark and nothing. Not even on multiple plugs. I did see what I thought was a super weak spark for about a millisecond and then it was gone, no longer to be seen.
      Before I pay for a new coil, how can I check it? What other pieces on this thing should I be checking for? I checked all the wiring and the main fuse near the battery. I have horn power and rear LED taillights working just fine. Bike wll not start with e-start or kick start of rolling it down a hill.
    • By TheVolta
      2006 Honda CRF450X
      Extremely clean and well maintained 2006 CRF450X
      oil changed after every two rides. Starts right up with no issues.
      Upgrade parts list:
      IMS 3.2g Extended Gas tank
      Noguchi Seat (Same seat used by HRC Dakar bikes)
      Renthal Fat Bar
      FMF Powerbomb Header and Pipe
      Highway Dirtbike Guards
      Renthal Clutch/Hotstart Intellilever
      Renthal Brake Intellilever
      Honda Airbox Mod
      Speed Cell Lithium Battery
      Acerbis Skid Plate
      Acerbis
      EK Did Chain and Brand new Sprocket set
      R&D Flexible Carb adjustment screw
      07+ Headlight Conversion
      Black Fork Guards
      OEM and JRC Plastics
      Spare parts included / original tank / New Rear fender/ OEM Exhaust/ Original Sprocket set/ OEM Bars / Filters
      **Willing to adjust price without OEM Handle Bars in place and no HWDB Guards. **
      Paypal and Venmo Accepted.
    • By Colin Greis
      ALL HELP appreciated.
      Bike: 2006 CRF450x Supermoto
      Back story: about 3 weeks ago went down on the pavement the bike landed on the left side, nothing broken other than bent shifter and a broken foot peg bolt. [to what I can see]. Rode home the bike (in pain) the bike sat for about 3 weeks while I let my body heal and worked on getting out the broken bolt and replacing the bent shifter.
      [Bike and Body ready to ride again]  The following ensues.
      Day 1: Started the bike up no problem using the electric start (seemed little bit louder than normal) rode down the street after about 5-6min of riding bike started to bog and wanting to die after slowing down for a red light the bike died. Would not start electric start or a kick, had to do the walk of shame and push the bike out of the road traffic. Got the bike started back up 5 mins later with choke on and on the ride home the same thing happen once more.
      That night did a oil change and looked at the coolant [ full to the brim]
      Day 2: After thinking about it... thought maybe my idle screw messed up from the crash. started to messed with the idle and the fuel screw. This seemed to some what help and got a quick 15min ride in no problems running a bit rich maybe had some backfires.
      Day 3: Added slip on FMF muffler that I ordered to replace the other crappy aftermarket muffler. took the bike out side and the electric start didn’t work just clicked away.. the bike started with the choke on using the kick start. [did not want to start as easy as it always does AT ALL] bike idled high for 1 min while I tinkered with the idle and fuel screws again, noticed smoke coming from the water pump area [front lower right] a plastic tube was touching the water pump maybe causing the smoke. turned off bike immediately. after the bike was off a small bit of white smoke was coming out the exhaust [not like oil smoke like (fire-ish) smoke maybe due to the brand new slip on.]
      So... what does everyone think whats my next move.
      Did I clog up my radiator when I a crashed?
      Break my water pump?
      Is the bike overheating?
      mess up my fueling?
      Please let me know! thank you.
    • By Bryan Bosch
      FOR IMMEDIATE RELEASE
      Honda Broadens CRF Lineup with Expansive New-Model Launch
      Largest performance off-road release yet includes new models for diverse applications
      IRVINE, Calif. (May 23, 2018) – During a recent “CRF Collective” unveiling ceremony at Fox Racing headquarters, Honda announced its most far-reaching range of performance off-road models ever, expanding the group by three and significantly improving the four returning models. Leveraging the brand’s unparalleled experience in the manufacture of dirt bikes, Honda’s performance off-road lineup now includes CRF machines for riding applications including motocross, closed-course off-road, pure off-road, and even dual sport.
      All seven models are based on the platforms of Honda’s revolutionary motocrossers, the CRF450R and CRF250R. Those two machines return for 2019 but with important updates, as does the closed-course off-road CRF450RX. In addition, Honda is offering a factory-replica version of its full-size motocrosser called the CRF450RWE (“Works Edition”). The trail-ready CRF450X is entirely new for 2019, and it’s joined by a road legal CRF450L that enables customers to connect trails via asphalt. Finally, Honda is also introducing an all-new CRF250RX closed-course off-road machine.
      CRF450L Dual Sport
      The trails are calling, and the all-new road-legal CRF450L answers, expanding customers’ off-road possibilities by enabling access to the best riding trails, even when that means connecting them via asphalt roads. Street legality is achieved via features like LED lighting, mirrors, and a dedicated exhaust system. Equally at home in the woods or desert, the CRF450L has a wide-ratio six-speed transmission for maximum adaptability, while a lightweight, 2.0-gallon tank offers great range. Compared to the CRF450R motocrosser, crank mass is up for tractability in technical conditions, where a large-capacity radiator keeps things cool.
      Color: Red Target Price: $10,399 Availability: September Info: https://powersports.honda.com/2019/crf450L.aspx >>> More pictures, video, specs & discussion on the 2019 Honda CRF450L <<<
      CRF450RWE (Works Edition)
      For the 2019 model year, you don’t have to be Ken Roczen to enjoy a CRF450R with factory enhancements, as the new CRF450RWE features a number of upgrades based on the bikes in the Team Honda HRC race shop. Rocketing to the top step of the podium through the use of a specially designed cylinder head with hand-polished ports, Yoshimura titanium slip-on muffler, and special ECU settings, this new model offers increased low- and mid-range torque. It also features the same graphics as Roczen’s No. 94 race bike, including a Throttle Jockey factory seat cover. Upgraded black D.I.D LT-X rims are included, along with black triple clamps and a gold RK chain. Titanium nitride-coated fork legs and an updated, titanium nitride-coated shock shaft increase traction and bump absorption.
      Color: Red Price: $11,499 Availability: August Info: https://powersports.honda.com/2019/crf450r.aspx
      CRF450R
      Already the industry’s top-selling motocrosser and the winner of the 2018 Daytona Supercross at the hands of MotoConcept’s Justin Brayton, the CRF450R receives a number of important updates for 2019. Better engine performance is achieved through a new combustion-chamber shape, as well as improved over-rev characteristics through a refined oil-management system. The frame and swingarm have been revised for optimized rigidity and weight reduction, while the braking system has been updated with a lightweight front brake caliper featuring a large-piston design. As a result of the weightsaving measures, the CRF450R is 1.76 lbs. lighter than its predecessor. For added performance and increased comfort, the 2019 model features new ECU settings, HRC launch control, a Renthal Fatbar® handlebar and adjustable handlebar position. Black rims and redesigned fork protectors are also new. This is how you convert the “Absolute Holeshot” into moto wins.
      Color: Red Price: $9,299 Availability: August Info: https://powersports.honda.com/2019/crf450r.aspx
      CRF450X
      Having featured heavily in Honda-mounted teams winning 20 of the last 21 Baja 1000s, the CRF450X gets a complete overhaul for 2019, based on the modern CRF platform but with off-road-appropriate features. A true off-road machine that’s ready for racing or trail riding, this model features a headlight, taillight, and side stand, as well as an 18” rear wheel and lightweight 2.0-gallon fuel tank. For maximum versatility in challenging terrain, the CRF450X also features a 49mm Showa fork with dedicated settings, wideratio six-speed transmission, and higher crank mass than the CRF450R.
      Color: Red Target Price: $9,799 Availability: October Info: https://powersports.honda.com/2019/crf450X.aspx
      CRF450RX
      Currently campaigned by JCR Honda’s Trevor Bollinger and Trevor Stewart in GNCC and WORCS competition, respectively, the CRF450RX inherits the same performanceenhancing features of the 2019 CRF450R, including an updated cylinder head and refined oil-management system, while still featuring off-road-specific features like a 2.2gallon resin fuel tank, 18-inch rear wheel, and aluminum side stand. Suspension is specially tailored to the CRF450RX and uses low-friction fork oil. For added performance and increased comfort, the 2019 model features new ECU settings, HRC launch control, a Renthal Fatbar handlebar, and adjustable handlebar position. Black rims and redesigned fork protectors are also new.
      Color: Red Price: $9,599 Availability: September Info: https://powersports.honda.com/2019/crf450rx.aspx
      CRF250RX
      Based on Honda’s successful 250cc motocrosser, the all-new CRF250RX joins the CRF450RX as a weapon for closed-course off-road competitions throughout America. Equipped with a larger-capacity, 2.2-gallon resin fuel tank, 18-inch rear wheel, and aluminum side stand, the RX makes quick work of challenging situations, its dedicated suspension and ECU settings helping the rider work through even the toughest trail sections. As with the CRF250R, HRC launch control, a Renthal Fatbar handlebar, and black rims are standard.
      Color: Red Target Price: $8,299 Availability: September Info: https://powersports.honda.com/2019/crf250rx.aspx
      CRF250R
      Newly introduced in 2018, the CRF250R has seen the GEICO Honda and TiLube Honda teams earn multiple wins in AMA Supercross and Arenacross competition, respectively, while also achieving success in amateur national races. For 2019, the model is revised with increased low-to-midrange engine performance for improved corner exiting. Inspired by the factory version, the Double Overhead Cam engine features updated cam profiles
      and intake- and exhaust-port profiles, a 50mm shorter right exhaust pipe, and a 2mm smaller throttle body. Riders can select from three engine modes for ideal performance depending on conditions, while HRC launch control has been adopted for improved race-start performance. A Renthal Fatbar handlebar sits in a four-position-adjustable top clamp, while the braking system has been updated with a lighter, CRF450R-inspired caliper with larger piston for optimum braking performance. Black rims are standard.
      Color: Red Target Price: $7,999 Availability: September Info: https://powersports.honda.com/2019/crf250r.aspx
      CRF150R / CRF150RB
      Raced by Amsoil Honda hotshot Hunter Yoder on the amateur national circuit, Honda’s smallest motocross machine returns for 2019, featuring a Unicam four-stroke engine thatoffers a spread of ample, useable power and torque across the rev range. Suspension duties are handled by Showa, with a 37mm inverted fork and Pro-Link rear link system. In addition to the standard version, Honda offers the CRF150RB, which features larger
      wheels, a taller seat, a longer swingarm, and more rear-suspension travel.
      Color: Red Target Price o CRF150R: $5,099 o CRF150RB: $5,399 Availability: August Info: http://powersports.honda.com/2019/crf150r.aspx
      ABOUT AMERICAN HONDA
      American Honda Motor Co., Inc., is the sole distributor of Honda motorcycles, scooters, ATVs and Side-by-Sides in the U.S. American Honda’s Motorcycle Division conducts thesales, marketing and operational activities for these products through independent authorized Honda retail dealers. For more information on Honda products, go to powersports.honda.com.
    • By moneypit
      Hello all. I just wanted to get some other crf450x owner input on something my brother noticed on my new bike. So this is on a newly purchased 2017 crf450x with about 4 miles on it currently. while riding around with my brother in my inlaws yard he pointed out that the head pipe was starting to glow red. I'm wondering if this is because the bike is new and is a bit hotter due to breaking in or if there is possibly a different issue going on with this new bike. Most of what i read suggests a lean issue presenting it self with the carb. i just installed a trail tech vapor kit on the bike but i doubt that would influence anything.  Any help would be greatly appreciated. hopefully this wont abort our first trip out to go ride it this weekend.
