Rekluse setup
Ok got the inch of free play with the clutch lever at half throttle. But when in first gear with the clutch pulled in and the throttle at 1/4 to 1/2 the bike stays still. But any more and it wants to start moveing forward. Any one else had this happen thanks
You have too much play in the lever. The easiest way to set up your lever is to ride the bike in a large open area. At full throttle in the upper RPM range you only need 1/4 to 3/8 of an inch freeplay in the lever.
It seems like i'll have the adjuster completey out. Will it hurt it with that slack
Mine is not completely out but close to the end. ASV lever.
What bike is it? Which Rekluse model is it?
There should be an adjustment somewhere in the cable. Find that and adjust it so that the adjuster on the perch is somewhere in the middle of it's range.
Having more slack at the lever won't hurt anything but not having enough slack will fry the clutch. You should be able to rev the bike in gear with the clutch pulled in without the bike moving.
