PROBLEM WITH DR-Z!!!helP plz
Currently my bike have this habit of making back fire when i release my throttle when moving.after i increas my idling the back fire became louder.My setting is jd kit 155 and 22.5 as my country is mostly sea level. slip on lv pipe and 3x3 mod. Does this back fire means its time to do valve clearance? oR is there anyway for me to DIY the problem by tuning back the carb.?
do help plz.thank you
Sound like it's lean , when letting off the throttle , main jet is not doing much.
Pilot jet or fuel screw needs a look at.
Happened to mine twice last summer, same, backfiring started from no where.
First time, pilot was plugged off by a tiny tiny black spec
second time, carb-intake clamp had come loose.
Does it start up and idle the same or are you finding you have to use alot more choke to keep it running, and are you using the stock air screw?
With just a slip on and stock header I think I'd stay with the 155.
How many miles on the bike, you are the original owner?
thx to those who replied.my bike is currently using pipercross air filter.the back fire came from the pipe and now i dont know how to adjust the fuel screw as i didnt change to keintech fuel screw.
Didn't you adjust the screw when rejetting ?
anyone know how to adjust the air and fuel ratio?
Running on a dyno with a wideband sensor and rejet
ok did my valve clearance.bike feel much better.but the backfire is still there when deaccelerate.OH ya one more problem just came to burn my wallet.there is a leak somewhere at the lower block.super stress rite now.i dont know whether i ride my bike with sufficient eo inside or it is completely drain.
The leak from the lower block might be coming from the front sprocket area and draining down. Check it out, it's a simple fix if it is from the front sprocket. HTH
My DRZ also makes a popping sound out of the exhaust when i decelerate. Not sure if it is normal but I would appreciate insight as well. I dont know much about this stuff.
