The Final Piece
a couple days ago I installed a JD jet kit and an MRD/SSW exhaust on my '09 SM and the next day I went to move my bike to take it off the stand and noticed this little spring lying on the floor under my bike. It's pretty small, only 3/8" long and 1/4" diameter. Everything seems to start and run good, just wanted to make sure it's not an important piece somewhere. Hopefully someone can pinpoint where it came from so it won't be in the back of my mind.
Do you have an FCR? It looks like the spring from an accelerator pump.
If you mean the one with the rubber diaphram, then no,, that one is much larger.
Hard to tell from the pic,, but if you have the OEM carb (BSR Mikuni) thats about the right size for the needle cap spring
it's a OEM carb that I have, I took the carb apart carefully and put it back together carefully but don't recall seeing this spring anywhere
and I did put in the extended fuel mix screw when I installed the jet kit
Pull the extended fuel screw and check to see if it has the SPRING, washer and O-ring. You need it if it is missing.
if it's missing from the extended fuel mix screw, is the order they're placed on the screw 1. spring 2. washer 3. o-ring
Like Bronco said, probably the fuel screw spring, but I remember it being a little longer than that. My memory sucks, though. :thumbsup:
That's correct.
I'll have to check it after work, but the thing that makes me think it didn't come from the extended fuel screw is that I pulled the carb and work on it on the table and I remember transfering the stuff on the old screw to the new screw. so that would kind of throw that theory since I found the spring under the bike after everything was all put back together and in the bike. This is gonna drive me crazy :thumbsup:
The only other small spring I can think of(besides the fuel screw) is at the front brake
no 10 here, but it looks longer
just checked the fuel mixture screw and it has one on there, so now the mystery of where this stray spring came from continues
If it's the BSR carb ,it is also a small spring on top of the carb needle.
no 5 here
What about the spring that sits inside the plastic retainer from the needle assembly?
Like Bronco said, probably the fuel screw spring, but I remember it being a little longer than that. My memory sucks, though. :ride:
That's correct.
Most people think it is longer than it really is :thumbsup:
I double checked the carb and everything is all together where it suppose to be with the correct parts in the carb. Any other ideas where this could've come from, it's pretty stiff for a small spring
  • Similar Content
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
    • By 4strokeOnly
      My bike was stolen, so I'm liquidating my spare parts.
      I took this off my S and replaced it with an SM unit so my speed would be more accurate with the street wheel setup.  I no longer need this spare.  I greased it regularly and it was in good working order when I removed it.  Included is only what is pictured.  Cable not included.
      Suzuki part number:  54600-29F00
      buyer pays shipping.
