jetting confusion.. MRD +stock carb
ok here it goes:
sea level
drz400 s 2000
stock carb
3x3 + uni filter
MRD/SSW
after reading for an hour i cannot grasp the difference between s and sm jetting setup, dont they have the same carb ?
this is what i think i understand:
160 main +25 pilot, 4th clip 2.5 turns... right?
but i also found that since i have a S i should put a 142.5 jet kit?
please clarify this,
As I understand it there are three kits Dyno Jet stage 1 and 2 and the James Dean kit.
The DJ stage 1 came out for the S and was not intended to be used with the 3x3. You can use it with the 3x3 but you have to buy a bigger main jet than comes in the kit.
The DJ stage 2 kit was made for the SM and the 3X3 so it has a different needle and comes with the jets you need. This can also be used on the S model with the 3x3.
The James Dean is a more complete kits, comes with two needles and is considered to be the best kit by users on this forum.
Get the James Dean kit and follow the instructions.
Thank you, iv just went over the master 3x3 post and all of its 42 pages,
one last question does the James dean kit come with the #25 pilot?
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
