clutch lever
I have a 04 ktm 125sx and I'm trying to adjust the clutch lever. It was to far out so I turned the knob to bring it closer. Now my bike has a noticeable pop when switching to first gear from neutral. The bike doesn't pull forward but it jest seems like a harder pop then before. Is this ok?
A good rule of thumb is you should be able to fit a nickle between the clutch and the perch if everything is alright with your actual clutch assembly.
so a knuckle between my handle grips and lever
Not a knuckle a nickle....lever free play. If your clutch is not enguaging until the lever is half way out the adjustment would not have caused any clutch dragging. Probably just a little paranoid after the adjustment.
