loose head nut
nope, take it off put on some blue locktite and snug it back up, how is your stearing? Too tight or loose?
You might want to loosen your top triple clamp, then crank the nut down. Then retighten the top clamp.
thanks that seems pretty easy, but how tight?tight as i can get it?
don't go crazy, especially if you use some blue locktite, just decently snug.
after doing some maintenice i noticed my stem/head nut whatever its called its slightly loose i can turn it by hand is it supposed to be like that?its the nut thats #1 in this picture thats loose http://4.bp.blogspot.com/_U8_oRrfOswQ/Spw7_L4pdKI/AAAAAAAAANU/aq0C6BDC-Ys/s400/Steering+Head+Bearing+Head+Crown+Adjusting+Ring+Nut.jpg
Haha... nope, torque it to: 128 N m (13.0 kgf m, 94.4 lbf ft)
After it's snugged up the steering doesn't feel so loose.
NOTE: there are NO nuts on a motorcycle that are SUPPOSED to be loose!
ok thanks thats what i read in my manual but i read online only to tighten it up a little so i wasnt sure.
