Husaberg 390 electrical problem!!
***NEW 2010 390 ELECTRICAL PROBLEM***
Postby KURTS78 » Today, 1:02 pm
When I try to turn on the engine with the magic button the bike does not turn on, the spark plug it is not getting power (spark), I checked all the connectors, cables, battery, etc and every thing looks good, if I push the bike it turns on very fast and the FI light it does not give me any error .. So this new bike is really driving me crazy!!!
PLEASE HELP!!!
Are you sure the battery connections are good?
There is the goo in the fuel filter problem, but this sounds different.
It must be something simple - good luck!
Ummm ... make sure that you don't have a blown fuse. They are located in the the little rubber box next to the ECU under the seat.
And if you do have one blown - look for a chafed/shorted wire. The major suspects are:
== the wire cluster behind the number plate rubbing against the frame
== the fuel pump wires against the exhaust pipe (below the gas tank)
Best of luck! E-Ticket
