XR400 engine cutting out?
2003 XR400, not sure why it almost cuts out when the engine gets to a higher rpm. I cleaned the carb twice, installed new jets 45 and a 145. New fuel tank screen. and have adjusted the pilot screw. Starts fine and smoth at idle. Sudden lose of power just before you would shift to second. Do you think adjusting valve clearance might be a fix. When I got the bike it would not start so I have no idea if it ran like this before the carb was cleaned. Thanks for any help...
That jetting is extremely lean for your elevation(I'm assuming near sea level). It must be completely stock intake and exhaust-wise. If it has any intake mods(snorkle under the seat pulled, aftermarket air filter and cage) or exhaust mods( other than the stock can or a modded stock can), then your jetting IS too lean.
If you haven't checked/set the valve clearances since you've owned it, then yes, do so, but tight clearances usually effect starting, and you said it's starting ok.
Check to see where the clip on the needle is set. Should be in the middle position, 3rd from top.
I don't suppose you checked the float level while you had it apart?
You say you've adjusted the fuel screw. How many turns out from seated do you have it now?
Make sure the carb vent lines are clear/not clogged up.
Post back here with your intake and exhaust configuration.
Checked float level and it seemed to right near .57 in. Clip is 3rd position, and started with the pilot screw out 2 1/4 then adjusted when running along with the idle screw. I will go out and check the vent lines. It has stock exhaust and the snorkle is gone.
Tried it with the vent lines off and still the same trouble. will check valve clearance when it cools off.
What about the air filter? Is it stock? Do you know the difference?
For the exhaust, look down the outlet, between the outer silver trim ring and inner outlet tube. May need a flashlight, but look to see if there have been any holes drilled there. You're looking for the Gordon mod.
If you took the float level measurement properly, using the correct technique as described in the manual, that .57" = right at 14.5mm, so that's good.
So, you started the pilot screw at 2 1/4 out. Where did it end up when you were thru adjusting it?
Do you use the choke to start it? I want to make sure you're positioning of the lever for on/off is not backwards. Off is all the way down, On is all the way up.
Jetting still seems screwy to me, but I'm not suggesting anything til I have these other questions answered.
I need to know from some of you other post Y2K year model 400 guys if the stock pilot is still a 52 for those or not. What about the stock main, is it still a 142?
Ok the jets in it were 55 and a 155 bad info to start sorry. Uni air filter and no snorkel. the valve clearance was real close, not the problem. Changed the main jet to a 168 and still had the same problem (higher rpm bog, very very bad) its at about 3/4 throttle. Ran it with the gas cap off, vent lines are clear. None of these things helped. Can anyone think of any other suggestions. thanks
I have not needed to use the choke to start it, I have pretty much left it in the down position. When the the engine is running it will stall if I put in in the upward position so I think thats fine?
OK, going from a 155 to a 168 is a huge jump. That's 5 sizes. What might have been lean before may now be too rich with that big of a jump.
Did you look for any holes between the outlet tube and spark arrestor end cap like I described earlier? I ask because if the snorkle has been removed and a UNI filter installed without also doing the Gordon drilling to the spark arrestor, you run into funny and difficult jetting issues trying to get the bike to run right. More airflow thru the intake, carb and engine means you have to allow more flow thru the exhaust or you end up with a bottleneck.
What's your elevation?
No holes and only about 700 ft. I think I will try some other smaller main jet sizes and may pull it out again check the needle position and float. will have to wait for a couple of days when I have more time. Thanks for your help...
I say, since the snorkle is pulled and it has a UNI filter, go ahead and do the Gordon mod to the exhaust. The "how to" is in a sticky at the top of this forum.
If the bike was originally sold in CA, it most likely has the A16 needle. The 49 state A16A needle has a different taper and is a very popular change to CA bikes.
How long have you had the bike? I'm wondering how old the fuel in the tank is.
Check the spark plug cap to make sure it's firmly attached to the end of the wire.
If you don't do the Gordon exhaust mod, then when you go to experimenting with the main, also try a smaller main, like a 152( 1 size smaller). Gage results between it and a one size bigger than the 155 you had in it to begin with( a 158).
I had a similar (not the same) issue with mine when I just got it... Mine was sputtering at high RPM and couldn't stay on idle.
The spark plug was loose (I tightened it and that was it)...
  • Similar Content
    • By 661Bran28den661
      What’s up guys. Totally new here picked up an XR400R I live in the desert so I’m riding often and enjoy it. But I am having some issues with my  01 XR400R. I brought it out this morning for a putt and it seems to be choking up in the top of second. Like a bog an go bog an go. First seemed fine and third I didn’t make it high enough into the rpms to see. Before I brought it back to the garage. Yesterday I also changed the air filter back to an uni. I had seen the other one had a hole in it and the box was dirty gunned up and oily. I removed the airbox gave it a good clean out wiped everything down very well put a piece of screen over the snorkel Or where it used to be I should say. “Lightly oiled the filter.Also the spark arrester an tip for the bike it did not come with I ended up making one with a piece of flat steel and drilling holes. Whilst doing this. I found also a crack in the pipe. It almost sounds as like there’s a vacuuming or whistle? When revving.The first one I had made worked fine I had no issues. This one I am wondering maybe if it’s a cause of a little too much back pressure.So I’m assuming it’s either a Carb or exhaust problem. Or something that could totally be minuscule. Or major issue. Would definitely like some second opinions and any advice would be greatly appreciated. Thanks guys!
      TWISTIN THROTTLES & CRACKN BOTTLES
    • By ddickinson
      My lanky 14 year old boy started showing an interest in riding MX/Off-Road so I sourced the best beginner friendly, yet dirt worthy, bike I could find: an Ol' Honda XR250R (2004). So far I've replaced a few clutch levers and perches with stock parts. That's gotten old and I'm looking to upgrade to an ASV or Torc1 type fold-able clutch/perch brake combo. Went to purchase online today and to my surprise there were no such parts listed for the XRs. I saw plenty of CRF/CRF-X choices and they seem to differ depending on generation. Obviously I can use nearly any perch/clutch combo as long as the two match; but I was wondering if anyone knew which of these levers was closest to stock? Also, will the first gen CRF250X brake lever work on the XR? These may be stupid questions to some; but I'd rather ask a dumb question than drop money on an ASV brake lever I can't use. Thanks for any help.
      #xr250r#hondaxr
    • By TheLastByte
      Im currently in the market for an xr400r, and considering buying one that's had some heavy engine work done. The current owner claims to have bought it from a friend who's an XR enthusiast. The PO installed a big bore kit and high comp piston, as well as a xrs only pumper carb, rsw triple clamp, aftermarket clutch, street lights, and a whole bunch of bling.
      My main concern is the effect the upgrades will have on the engine's longevity. How much quicker will I be going through top ends with the setup on this bike as opposed to a stock setup, and should I be worrying at all about bottom end longevity as well? I wouldn't mind having to eventually redo the top end, but I don't want to deal with a race bike type top end rebuild schedule on an XR.
      Is there anyone here who's running a bike similar to this one who can give some advice?
    • By Ralph303
      I have a 2001 Honda XR400R. It has a whirring/grinding sound in the lower end and a vibration in the top end. I pulled the valve cover and everything looks good. Decompression lever looks to be in order. Anyone know where I should start looking or just rebuild the whole engine. Ballin on a budget, but really love this bike. It looks like it’s new otherwise. Oil was jet black and thin. Thanks in advance!
    • By junglePIG
      Hi, I have an Xr250r with a buckled/ wobbling front wheel, after trying to true the rim i have broken a spoke.
      I am wondering if it is possible to lace any 36 hole aftermarket rim to the oem hub, also will i need to buy an xr250r specific spoke set. also could i take a 36 hole rim from another front wheel and lace that up???? thanks
