KLX250 fork springs for EFI?
Hello!!
Greetings to all my name is Roman, I live in the Canary Islands and am very happy with my KLX250 kawa but ...
I'm looking for some harder fork springs for kawasaki KLX250 2009, but appear not to exist. Not adjusting the Race Tech, Ohlins, Eibach ... models are available for previous years and the 2009 has 255mm of travel.
Its spring is 415mm long and 0'397kg / m of hard, I need 0'436kg / m
Can someone help? there is a dock compatible?
Thank you very much.
What is the OD of the spring? Let me know and I'll see what I can find for you.
Hello rks1!!
The outer diameter of 37'4-39mm, and internal 28'4mm.
The fork is a 43mm KYB similar to the KLX300 but the internal route has been shortened to 255mm.
As additional data series comes preloaded with a 13mm and I can not raise the level of oil because it has a distance of 80mm.
I want to solve the problem of soft spring because I think that until we could not modify this setting an improvement in behavior.
I read once that might be useful BBR springs used in the CRF230, but I'm not sure. Are there specific market harder springs for new models KLX250? looks amazing with a relatively popular motorcycle.
Thank you very much
