01 cr125 jetting question
got my first race comming up this week and im tryin to get my bike dialed in. my question is if i turn the screw on the carb to the right does it lean it out or to the left leans it out? im just trying the get the throttle resonse as good as i can. sometimes the bike has a slight bog or hesitation when i open the throttle. i know they came from the factory rich but im tryin to work with what i got u know.
screw is air control, so turning out = leaner.
air screw only affects 1/4 throtle and less
1/4 to 3/4 throttle jetting is the needle: raise clip = leaner
set air screw 1st, then adjust needle.
make sure silencer is freshly packed nice and tight, makes a difference
