230L brake pedal on 230F?
I like the looks of the 230L rear brake pedal and am wondering if it will fit on a 230f. They don't have the same parts numbers. Bad thing is, it's like $65 for the L pedal! It would go well with my mounts!
If you don't mind performing some fabrication, it might work out for you. The L is fitted with a disc / hydraulic rear brake. The F model is drum / mechanical.
I didn't realize that. I'm sure you could put the L rear brake system on the F and get disk brakes and a better shaped pedal!
That guy "Papa Smurf" just decided to part out his 230L on Ebay. I'm sure you could get the brake pedal pretty cheap. The 230L parts may not be up yet but they will be at madmikesmotorcyles.com.
