Dr650 gearing
I am currently running a 14t front and stock back sprocket on my DR650.
I would like to gear it even lower so that in first gear the bike will not stall while running at idle speed. What sprocket combo would work best. Top speed not important as 65-70mph would be suficient.
the biggest problem with the dr650 is the carburettor is lean as shit.
if you move the neadle up one notch and richen the idle mix it should be ok.
The carby is the only reason why the bike wont pull away at 1500rpm.
