No powerband?
I'm trying to get my kx250 dialed in. The bike has vforce reeds, full procircuit exhaust, and a new top end. I have cleaned the carb, and the exhaust valves are clean/adjusted. I was surprised to see the bike had the stock main jet, but all summer the plug has been wet and fowled every month or so. My buddy has a stock yz250 with the same jet and his bike runs great. Since I'm in Nh and wanted to ride on the ice I bumped my main up a jet, so did my buddy and my bike was bogging out bad in the top end while his was pulling harder. I kept fowling plugs, and was under the impression my bike should have been jetted richer since my engine should be breathing better than his? I'm at a loss my intake looks good, reeds are clean, I was thinking possibly ignition since it advances based on throttle position?
Read the plug, listen to the exhaust note, feel for bogging/lean running. If your bike is running rich then lean the jetting out. I do know with my rad valve I had to lean my jetting up. So maybe its the same with the v-force.
If you don't have a powerband, check your powervalve spring, might be broken or disconnected.
Most likely you went the wrong way on the jetting. Are you sure that the powervalve timing is right? If it ran well before the rebuild and now it lacks hit I would suspect the exhaust valve. Fortunately you can check by removing the pipe and linkage cover.
Comparing jet specs between two completely different bikes is useless.
Your bike "breathing better" because of a pipe and reeds will not require you to make the jetting richer, in fact just the opposite. Increasing air flow through the carb venturi causes a corresponding drop in pressure (the Bernoulli Effect), drawing more fuel up through the jets and making the bike run richer. Adding the pipe and reeds made your jetting too rich, most likely on every circuit.
Print this out and follow it. You can easily cure your problem.
Spanky's Jetting 101:
A correctly jetted carb makes a tremendous difference in the torque, midrange pull, top-end pull, and over-rev of your engine. If you have never jetted your bike correctly, you will almost certainly gain some performance at some point in the bike's powerband.
A cleanly jetted pilot circuit can be the difference between having to clutch the bike out of a turn or not. Hard starting when hot or cold, poor response when opening the throttle, reluctance to idle, all of these are symptoms of an improperly sized pilot jet or incorrectly adjusted air screw.
The needle can make all the difference in the world for the power of the machine in most situations, as it controls the throttle range that most riders spend most of their time using.
A correctly sized main jet could mean the difference between being able to rev out high enough to not have to shift one more time at the end of the straight, or the power falling flat on top and requiring you to make that extra shift.
Are you fouling plugs? Many people will tell you all sorts of band-aid fixes, from running less oil, to running a hotter plug. Both are incorrect fixes for plug fouling. It's all in the jetting. An engine that is jetted too rich will have combustion temperatures that are too low to burn the fuel and oil effectively, leading to deposits and wet fouling of the plugs.
Do you have spooge? There are the rare instances where a mechanical issue, such as a leaking wet-side crank seal, can cause spooge. But, by and large, this isn’t the case. In most instances, spooge is caused by rich jetting. It has nothing to do with how much oil you mix in the gas, or how hard you ride. An engine that is jetted too rich will have combustion temperatures that are too low to burn the fuel and oil effectively, resulting in deposits, plug fouling, and spooge. Spooge is nothing more than unburned fuel and oil entering the exhaust.
The only way to know what jetting changes you will need is by trial-and-error. No one can give you jetting specs, because every bike is different, every rider has a different style, and jetting is totally weather dependent. Unless the person telling you what jets to use is riding an identical bike, on the exact same track, at the same time, his recommendations are meaningless. Someone with a good understanding of jetting can get you in the ball park, but you need to do the testing to determine the correct jetting yourself if you want it right.
Jetting is fairly simple, and is a useful skill to learn if you ride a two-stroke and want it to perform at it's best.
It's very important that you start with the pilot circuit, because the pilot circuit affects the entire throttle range. When you are at full throttle, the main jet is the primary fuel metering device, but the pilot is still delivering fuel as well, adding to the total amount of fuel that your engine is receiving.
Before you start to re-jet your bike, you need a clean air filter, a fresh plug (actually you need several plugs to do plug-chop tests for the main jet), and fresh fuel.
One important detail: Make sure the engine is in good mechanical condition. If your engine has a worn top-end, fix it first. Trying to jet a worn out engine is a waste of time. The same goes for reeds that don't seal properly, and a silencer that needs re-packing. Worn reeds will mimic rich jetting, and worn rings will mimic lean jetting.
Before you start the jet testing, Install a fresh plug. Set the float level to the proper specs, an incorrect float height will affect your jetting all across the throttle range.
All jet testing must be done with the engine at full operating temperature.
As already stated, start with the pilot circuit. Turn the air screw all the way in, then turn it out 1.5 turns to start. Start the engine, and turn the idle screw in until you get a slightly fast idle, or hold the throttle just barely cracked, to keep the engine idling. Turn the air screw slowly in, and then out, until you find the point where the idle is fastest. Stop there. Do not open the screw any farther, or your throttle response will be flat and mushy, and the bike may even bog. This is only the starting point, we will still have to tune the air screw for the best response.
Now is the time to determine if you have the correct pilot installed in your carb. The air screw position determines this for you, making it very simple. If your air screw is less than 1 turn from closed, you need a larger pilot jet. If it is more than 2.5 turns from closed, you need a smaller pilot jet. If your engine doesn’t respond to air screw changes, then you either have a dirty carb, or the pilot jet is way too rich. When the pilot jet is way too rich, you are forced to use the idle screw to open the slide so far in order to keep the engine running that the pilot circuit is partially bypassed, and the engine is actually starting to draw fuel through the needle jet.
Once you have determined (and installed it if it's necessary to change it) the correct pilot jet size, and tuned the air screw for the fastest idle, it's time to tune the air screw for the best throttle response. Again, make sure the bike is at full operating temperature. Set the idle back down (the bike should still idle, despite what you read in the Moto Tabloids), and ride the bike, using closed-to-1/4 throttle transitions. Turn the air screw slightly in either direction until you find the point that gives you the best response when cracking the throttle open. Most bikes are sensitive to changes as small as 1/8 of a turn.
The air screw is not a set-it-and-leave-it adjustment. You have to constantly re-adjust the air screw to compensate for changing outdoor temps and humidity. An air screw setting that is perfect in the cool morning air will likely be too rich in the heat of the mid-day.
Now, it's time to work on the needle. Mark the throttle grip at 1/4 and 3/4 openings. Ride the bike between these two marks. If the bike bogs for a second before responding to throttle, lower the clip (raising the needle) a notch at a time until the engine picks up smoothly. If the bike sputters or sounds rough when giving it throttle, raise the clip (lowering the needle) until it runs cleanly. There isn't really any way to test the needle other than by feel, but it's usually quite obvious when it's right or wrong. A too-rich needle can often be felt simply when revving the bike on the stand. The bike will sound rough and raspy when blipping the throttle on the stand. A correctly jetted bike should rev cleanly and crisply.
Last is the main jet. The main jet affects from 1/2 to full throttle. The easiest way to test it is to do a throttle-chop test. With the bike fully warmed up, find a long straight, and install a fresh plug. Start the engine, and do a full-throttle run down the straight, through all gears. As soon as the bike tops out, pull the clutch in, and kill the engine, coasting to a stop. Remove the plug, and look deep down inside the threads, at the base of the insulator. If it is white or gray, the main is too lean. If it is dark brown or black, the main is too rich. The correct color is a medium-dark mocha brown or tan.
Please note that, when reading plugs, the tip of the insulator, threads, etc. are meaningless for jetting purposes. They can tell you a lot of things, but jetting isn’t one of them. Only the mixture ring at the very base of the insulator, inside the threads, can tell you anything about the jetting.
These links should help you to understand reading plugs:
The slide is also a tuning variable for jetting, affecting the throttle range from 1/8 throttle to approximately 1/3 throttle. If you can’t clean up the small-throttle jetting on your bike no matter how lean you go with the pilot or the needle, the slide is the next step. But few bikes need leaner slides.
Keep in mind, even though this article is intended primarily for two-strokes, four-strokes also need proper jetting to perform right, although they are not quite as fussy as their oil-burning cousins. The only real difference in the two is with the pilot circuit.
Two-strokes have an air screw that you screw in to make the jetting richer, and screw out to make the jetting leaner. Four-strokes, on the other hand, have a fuel adjustment screw that you screw in to make the jetting leaner, and out to make it richer. Their purpose is the same, they just do it in different ways.
The bike never really was snappy, so I did the top end it needed to be done anyway. I checked my main with the procircuit site, and it's the right jet (158). I'm going to check the needle tonight and air screw. When I put the power valve together I pulled the valve full open, then put the gear on and turned that counterclockwise until the straight gear hit the cylinder, then tightened the gear. I never touched the drum valves, but they did move freely.
Have you made sure the right side crank seal isn't leaking? That will screw with your jetting, as well as foul plugs.
Don't take jetting recommendations from any web site as the gospel, those are only recommended base-line settings. They don't know how or where you ride, what other mods you may have, what the weather is, or what altitude you ride at. You still have to do some testing to finalize your jetting for the current conditions.
I have not noticed any loss in crank oil, nor seen any oil burning. How would I check it? I know the carb cleaner while the engine is running trick, but it obviously won't work here. The bike has also started hard since I've owned it, it takes about 20 kicks on a hot summer day.
I dropped the needle one notch. It was in the Stock (3rd) position. I'll see how that goes. If it helps I'm at sea level, have the pipe, reeds, and airfilter. My main is a 158, I believe stock pilot, air screw is 1.5 turns, and now the needle is raised a notch, but I think Ill need to lower it. I should be in the ball park now.
That's so good S**T. Should be a sticky somewhere.
Since the bike starts hard and chokes itself out, I finally did a leakdown test. The plug was brand new and not black at all. During the test I found the base gasket leaking. I'm thinking this air leak would cause the bike to start hard and have no power?
