2007 ktm 250sxf bog on wack of throttle plese help!!!
:bonk:ok i have a 2007 ktm 250sxf
has powerbomb header and titanium muffler / stock bore
i installed the jd jet kit with the o ring mod , 5th clip red needle , 185 main , and a 60 leak jet
it was 45 degrees here today and i started the bike after i installed my new rekluse z start pro and i took it for a ride it still has the same bog it did before installing my jd kit say when u come to a bottom of a hill and wack the gas hard it falls on its face
where do i go now ?????????? any help is great
thanks,
john
forgot to say i am at or very close to sea level upstate ny
thanks,
john
i dont really care for 4 strokes too much i bought this bike for the right price so its a spare and back up bike my main bike is a 2009 ktm 300xcw(2 smoker)
how do i time the ap squirt????
and where whould i find an adj leak jet???????
shouldent the jd kit took care of this bog as they claim???????
thanks in advance,
john
I went thru the same thing, runs good if you roll the throttle on, asked lots of people, JD included, changed lots of stuff. Turned out a few were right, top end was worn out and it needed a re-build. Fixed and runs great now. 50 hrs for racing, 100 hrs trail riding, mine had 150 hrs or so.
You might need to change the leak jet or get a Merge Ajustable leak jet. That way you can adjust it on the outside instead of taking the carb apart.
even if i put the leakjet that jd rec. and used the 1 that came in my kit??????
im just lost here i bought this kit to cure this bog as james dean told me it would
thanks,
john
thanks,
john
Some times you may have to fine tune it. Have a read of this http://ktmtalk.com/index.php?showtopic=171766
I think Ive read what Mike suggested before, worth looking into.
