Upper Triple Clamp Question
I'm wanting to change out my stock triple handlebar clamp (2002 DRZ 400 S) for something like the Zeta triple (or anything similar). I have purchased a certain aftermarket headlight which requires crap-canning the stock headlight mounting frame which won't work with the existing headlight . The particular headlight is the one for the Drz by Britannia Composites. Web address is : http://www.britanniacomposites.com/lynx.html)
The headlight/fairing mounts into the same hole on the stock triple that the speedo bracket does. My question is whether the ZETA triple or any other aftermarket trriples have the same mounting holes brazed onto the front facing portion of the triple. If they do not have these mounting holes, would it be difficult to braze one's on?
Thank you. I checked out the BRP Site. I'm close to buying one over the ZETA. The black looks real nice. Upon ordering one, there are some selections they ask. One is what bar mount height . Choices are 31.5", 34.5" and 41.7".
They refer to 34.5" as stock. Which one did you go with and why?
Also, what bar position RTS did you select and why? This stuff is a little confusing to me. I wondered what your preferance was. I prefer to ride 80 percent off road and am looking at the Pro Taper EVO 1.1/8th as a bar.
I went with the BRP because of the mounting holes and big plus was the black anodize finish. First rate product. I chose the stock height for the clamps and the smaller (or closer to stock) RTS bar position. I am 5'10". Also went with the EVO bar. Feels great. Looks great....
