2010 CRF250R Folding Brake Lever?
Are there any folding brake levers for the 2010 CRF250R out there?
The 2009 Sunline or other brand brake levers will not work on the 2010!
I got the ARC folding lever that is the 07-09 CRF250R model but it works fine. It has a hole machined in it that accepts the ball end of the push-rod. The only thing that is missing from this design is the interface/design for using the spring that is on the OEM lever. This would be nice to have because I think it might help keep your pads from dragging, but so far I have had good luck with my lever. Another negative is that the rubber boot does not fit over the ARC lever perfectly. It will work and it does give some dust protection...just not quite like the way it fits over the stock lever.
sunline does have one that fits.
email greg berg at gregb@sunlineracing.com
thats who hooked me up.
was months ago though.
one industries has bought out the valencia sport group or whatever.
not sure if greg is still there or if the email is correct.
just checked.
part number BK-117N
Yeah any lever from 07+ 250 or 450 should fit fine. :thumbsup:
not true with sunline.
tolerances were whack.
their lever fits too tight.
new part number = no problem.
Bought the sunline lever. Had to drill out the retaining bolt hole. Took half hour to make it work but now works great. Must of been one of the ones before they were matched to the 2010.
