Suzuki LTZ400 do I need a tps sensor
Does anyone know what the tps sensor does in the ltz life and what would happen If I just did not hook It up. also lets just say If I was to put a carb off a ktm would the sensor plug up could I splice into it and put the ltz plug on it. Im lost and do not want to spend $700.00 for a new 41mm carb.
well i hope you dont spend $700 when a used one can be had for less than half that.
i dont know all your mods but a 41 mm may be slightly big , a 39mm will work just fine and and can be bored when you are ready for it to be bigger.
get a 39mm from a YFZ ,remove the TPS and get a dynatek CDI and you will still be way under $700
