I heard cr250 hub will fit ktm 520... same dimensions?
Has any one else heard that a cr250 hub is the same dimensions and will fit a 01 ktm exc 520?
which hub, wheel or clutch?? I have not heard of this working. Some KTMs use the same clutch plates as a Honda tho.
Edited by Mike in Fresno
oh sorry i should of been more specific. no the wheel hub... Someone said that in a post a while back
i know a drz400 (and other Japanese bikes) rear wheel is a direct swap with no work or parts. front wheel swaps onto ktms are more time and $ consuming (bigger front rotor)
never heard of this either and would be very cautious of the axle diameter, sprocket and brake rotor spacing.
i think it was like the 02s and up cr250r they changed to a beefier axle that jst happens to be the same diameter as my bike
simple check then...check spacer widths, gap between sprocket and rotor, diameter of rotor, thickness of rotor, offet of sprocket from spacer edge, and total width of hub from spacer to spacer...easy
