PW 80 help!
I have an 03 PW 80 that has started running poorly and need help! The bike starts and idles fine, but when put under load, and especially and 1/2 throttle or more, the motor bogs down and acts like it's going to die. I took the carb apart and cleaned it thoroughly, which seemed to help but no solve the problem. I also changed the plug, cleaned the piston top, and cleaned the exhaust port. The bike will accelerate to speed in first gear, then when shifted to second gear at low (1/4) throttle it responds fine, but as it picks up speed and throttle is opened further the motor stumble bad:foul:. Any ideas and help would be greatly appreciated! Spring is coming and the kids need this running well.
