Engine not idling
I took my 50 out to tune it today and I think I got it tuned in pretty good and was playing with the idle because it was idling high and I got that done but then when I took it for a ride for about 15 mins I wanted to see it idle in neutral and it took like 2 minutes to idle down it sounded like I was just barely on the throttle and then it idled down finally. I played with the throttle a bit thinking it was stuck or something and that did nothing. Is this normal after riding it hard for a while or is it something with the carb? I have a stock 50cc engine with a stock carb and #58 jet. It just has a freshly oil uni filter and a fmf exhaust. I also noticed on accelaration there was a little little white smoke. Am I running to rich or is it the oil from the filter because I think I might have put to much on
My guesss is too much oil on the filter and/or plugged pilot jet
Yeah I soaked both filters the inner and outer in oil and then I later read that you should just do the inner filter. Will the oil eventually dissolve or should I wash it out? I just cleaned the pilot but maybe all this oil clogged it so I will check it again.
I also just adjusted valves also so I dont think its that. Is there anyway to check if any of my gaskets are leaking? Just do a compression test right? What should the compression of a stock engine be?
