TTR125 Clutch arm spring replacement.
I need to replace the return spring on the clutch arm on a 2001 TTR125. Ive removed the circlip around the shaft but it still wont lift out. Has anyone replaced this before? Do you need to take the clutch cover off and remove the pushrod?
Im trying to figure out how to get the pushrod out. But based on what i have seen under the clutch housung so far, along w the parts diagram, I dont see how the clutch arm would come out WITHOUT removing the pushrod (and therefore the clutch assembly)
