06 rmz450 rear wheel bearing help
so i cant get the spacer to move enough to even get a punch on a bearing... anyone? does your spacer allow you to get a punch in there? mine might just be stuck, despite how hard i was hitting it.
lay the wheel on the floor. I have a steel rod about 20 inches long, 3/8 in diamter. I put it about 1/2 way through the tire and cock it sideways. The center collar (inside the wheel between the two bearings) will usually move a bit once you do this a few times. Once it moves, you can see the other side bearing's inner edge.
Hope this makes sense.
