Leatt straps vs headbands
When you aren't using ur leatt with a cp do you use the straps that come with it or the headband style. What pros and cons do you have. I'm kinda a big guy 6'2 and about 200lbs will the headbands even fit across my chest?
Thanks :thumbsup:
I run mine without any strap.About your size as well.
so do you just run the brace tighter?
No your brace should rest on your shoulders comfortably.No air gaps between the brace and your shoulders.You don't want the rear portion putting any pressure on your back or the front putting pressure on your sternum.I hated the strap and only ran it a couple of times.Others love it so........IDK?Go to the Leatt site I think they have fitment guidelines.:thumbsup:Good luck.
Well i just bought the headbands to keep the brace down and in trying them on it feels like it is more secure than the straps that come with the brace. The only problem is that they feel a little tight around my chest and neck. Do you guys think they will stretch or not. If not are there things that i can do to make them stretch?
