School me on the Husky XC
i have been looking for a old but new to me husky for some time..i do not want an all out race bike with high compression...just a decent woods/cow trail bike...would the husky XC fit the bill?....or is it as well a high compression monster....would the WR be compatible?....just need some info on all these different husky alphanumeric disgnations..thanks..god speed
I ride a WR 250 , she is no bother when treated with respect, its as fast as your right hand will let it go............ even though mine bit me:worthy:
depends on what year and size...
the XC is a cross crountry model, close ratio down low 1st-3rd, then wide up top.
a bit taller suspension, close to the CR..lighting coil.
the head on the CR WR and XC is pretty much the same, so no real compression issues.
however...the 78 to 80 OR has its own head, pipe, intake ect..kind of a one off so to speak.
unless your looking to collect, id avoid getting an OR...{off road} thats pretty much an early XC.
if your looking at the 81 83 XC not a bad choice, if you can find one cheap...good luck.
84 to 88 XC is hit and miss, the issues to look for, are, water pump issues until 87, electrics all years, and radiator problems..
thanks....id buy a new bike but the damn things are just too tall for a 5'10 guy like myself....i miss the days of 17 inch rear wheels and 19 inch fronts...luckily i have several of those old bikes in my garage from 36 years ago...no water cooled crap will ever be in my garage either...so i guess 81 to 83 husky fits the bill.....i remember the day suzuki came out with water cooling...no fins what a shock then..i also remember the carter years so i am dating myself here...thanks again..god speed
I rode my 79 CR250 in some single track a few times and it was so light and flick-able it was like a 125 only better and it held its line so well it again was very safe and easy to ride n the semi-gnarly stuff ... Ground clearance was a shorter than todays bikes but it was really cool riding it out there... I had to keep the RPMs up on the high side but that again was not a problem ... :banana:
These models are 6-speed trannies...
The Husky XC250 (1982) is very fast, tall, and long. Parts are not easy to find either. If you want a Husky just to use as a daily trail rider, I suggest getting a left over 2008 or 2009 model. If you want a Post Vintage racer then the XC250 would be fine.
X2 what Dwight said!
The current 2010 WR model goes back to 2005 and what I mean by that is all the plastic and parts are similar and interchangeable with the exception of the KYB forks and triple clamps on the 2010 WR250 model.
The late 70s and early 80s Huskys are cool, but they really don't compare to the newer Italian engined Husqvarnas.
If you want to do it on the cheap, look for a 2005 model WR250... and then find a 1995 thru 2003 WR250 parts bike on CraigsList or in the broken bike pile behind a bike shop... the nice thing about the italian Huskys is most of the hard parts are interchange between 1992 and 2010. Lots of years lots of bikes... GREAT MOTOR!
Good luck on your quest. :banana:
BlipBlip/HuskyRips
  • Similar Content
    • By Big64N
      Good condition with a long list of high end upgrade parts.
      Rekluse EXP 3.0 with cover and slave
      EVO- Ellensburg suspension tuning for 6' 200# expert rider
      Fork bleeders
      Trail-tech map switch
      Moose 1-1/8 flex bar
      CYCRA probend bar guards
      SXS skid plate with linkage plate
      Clutch and water pump guards
      Frame guards
      Fastway Evolution III pegs
      SRT Pro Armor radiator and rear rotor guards
      Acerbic Front rotor guard
      TM designs chain guides
      DID race chain
      Renthal sprockets
      Gripper seat
      FMF F-bomb header
      Dirt Tricks timing chain tensioner
      Pro Wheel, wheels
      Tubliss front and rear
      New top end and valve adjustment 60 hours old
      Many more aftermarket parts as well as spare parts and service manuals included in the sale.  Willing to include 4 sets of tires with 80% tread left for full price.
      Great bike with plenty of life left and set up for anything from single track woods to wide open dessert.
      Can hang with any of the 450's but is much easier to handle in the tight woods.
      Priced to sell at $6000.00
      Willing to consider reasonable offers but no trades or carry.
    • By Dean.b
      Long story short I bought this 2011 WR300. The thing is mint, looks brand spanking new. The thing ran like a top, but only had one problem, a low idle. I was to lazy to fix it and just dealt with the fact that I always needed to keep a little bit on the throttle. My third ride on it, I took it to the florence dunes and the top end burnt up. I have just finished fixing it and all I need to do is break it in. I need to adjust the idle first though, and don't know if I'll have the idle too high until it starts. I don't want to hurt the motor on a fresh rebuild and want some opinions on what to do. Do you think it will be fine? How many turns out should I set the carb just to be safe?
      Any response helps
      -Dean
    • By dorilabo
      #Husqvarna
      #CR125
      #2-Stroke
      #Maintenance
      #Advice
    • By motoxtremist
      Just bought a used 2017 Husqvarna FC450. It's my 1st EFI bike so I'm hoping someone can help me out with this issue.
      After starting the bike cold and idling for about a minute or two, it blows a puff of blue smoke from the exhaust pipe if I roll the throttle. It also does this if I stop to talk to a riding buddy on a trail or on the side of the track, let it idle, and then start out on track again. After revving it once the blue smoke is gone but riding buds have told me they smell and occasionally see a puff of blue smoke when following me - not a constant stream just a puff and then it's gone for a while. I'm talking to myself over trying to locate the cause of this as a leak-down test shows no issue.
      Bike history
      Bought used with 70 hours on it.
      Original owner had an FMF header and tailpipe on it which he kept. He sold it to me with the stock pipe. He never had it remapped for the FMF pipe
      Started it's life in Atlanta GA
      Now mostly ridden at sea level
      He told me he used mineral-based 10w-40 Yamalube oil. The manual calls for 10w-50 Ester-based synthetic - which the bike is now running.
      This is what I've tried so far:
      Leak-down test produced only a 3-5% loss.
      No bubbles in the coolant with the cap off
      No air leak at the exhaust pipe
      No leak at intake
      Barely, barely noticeable hiss when I remove the oil fill cap - but again not enough to lose any more than 5% pressure during the leak-down test.
      Wouldn't matter but checked the valve clearances while the valve cover was off. They were in spec.
      No loss of power
      No milky engine oil from a coolant leak
      No loss of engine oil as seen at the engine oil level window - never needed to add oil between changes
      Talked to someone who builds motors for a living and he said "all KTM/Husqvarna's do it especially when cold because the EFI delivers more fuel on startup as opposed to running at operating temperature". I guess I can see that but why does the bike blow blue smoke at operating temperature then if I pull off the trail or track for 1 minute to ask one of my riding buds something? I'm not letting it idle for minutes at a time. 1-2 minutes tops. Is this just normal for KTM/Husqvarna/4-stoke racing bikes?? Any help would be greatly appreciated!  Former bikes where 2-strokes (CR250, RM125) and a 1993 DR350 which I could've let idle for 20 minutes an not seen blue smoke - but that was a carbed bike. I've always known if a 4-stroke is smoking blue it's burning oil and you shouldn't keep riding it. So I'm a bit concerned about whipping it around the track or taking it out a few miles on trails.
    • By MotoXRacer_19
      As the title suggests, I've been debating the idea of throwing in a high compression piston. It will bump the compression in my 2014 KTM 350 XC-F from 13.5:1 to 14:1. First and foremost my main question is, because I live under 1000 ft and usually run 97 octane REC gas, will I have to change the fuel I run or not? Also, will I have to change out the cams to aftermarket and re-time the whole motor and ignition? I guess I really don't know what to expect so any advice will definitely help! Attached below is a photo of the bike I plan on putting it in.
