Dropped in creek
Dropped on right side in water for 40secs. Cracked clutch cover. Removed spark plug nd got it going. Now will on run at higher revs nd backfires a lot. On trip so trying garage in morning. Will seek to weld cover nd replace oil. Carb was running bit rich. Likely problem with carb? Or bent valve? Seeking advice.
How deep was the water? Is there water in the air filter or filter box box? Dose the carb have water in it ?
