What Kind Of Oil Do You Guys Use?
I was just wondering what kind of 4t motor oil you use in your bikes. The manual says to use genuine stuff because it lube the motor and transmission.
Holy cow Batman! Another oil thread! We gotta nail this sucker :banana:
There are lots of good oils to choose from ... Many like the Shell Rotella stuff... Lots like the true synthetics ... then there are blends of these two types ... All are very good. How deep are your pockets?
i dont want anything more expensive then yamalube. i guess my real question can you use conventional motor oil, not motorcycle stuff?
If you want and inexpensive, good oil. Use Rotella T 15w-40. It's a high quality diesel oil that also works great in bikes. The best oil is clean oil, I change mine every 3 hours max.
What about 2s tranny oil, i been putting in belray 80w but the manual says 30w, my tranny feels a little clunky, though it is new.
I use supertech from wal mart in the 20L jug for 45$. cant go wrong at 2.25$ per liter, or about 3$ per oil change.
its diesel oil, just like rotella T. and does the trick just fine. rotella is a tad more expensive so I dont use it.
Genuine? You mean as compared to fake? :banana:
I ran Shell Rotella T in my YZF.
80W gear oil is approximately equivalent to 25W engine oil.
The 80W is fine, as is 10W30 oil, or ATF.
so the guy i bought my bike from ran only honda gold bottle red cap in it, well the only place that carries that here is a stealership and they want 9.50 for a qt, if i switch to the rotella T 15w40 will it cause any problems? just lookin to save a little doe, i dont ride my bike hard and i dont race it. thanks
How often you change it is far more important than what you run in it. You'll be fine with the Rotella.
this is 100% absolutely correct.
I run the cheap, 2.50$ per liter oil, but I change it often.
some guys run the 25$ per liter oil and use it all summer.
I think I would rather have a "low" quality oil thats ALWAYS fresh, versus an expensive oil thats used, beaten, burnt, dirty, filled with metal shavings (most bikes share the clutch and engine oil, dumb IMO), etc...
Even cheap oils of today are better than the best oils were a few years ago.
iv found so many different threads on what ppl say is "good" and whats not "good" for the bike. im kinda confused on what to do i dont wanna run honda oil anymore cause of the price, so im gunna start running the rotella synthetic in the engine side, will that be okay for the tranny side too or do i need something thicker?
+1
I run 'cheap' oil in everything I own, super tech, mobile clean 5000, or rotella are what I use almost everytime :banana:
I personally don't like running overly thick oils in anything like some people do, I try to run around manufacturers weight maybe vary the weight a little according to extreme temperatures..
And I can't 'prove' anything about automotive oil being ok for the tranny or anything, I've just always had great success... But I've NEVER had a clutch go out on any of my bikes, and I ride them hard, and always use automotive oil. So I will say they don't harm clutches as long as you don't run fully synthetic energy conserving oil :lol:
40k on stock clutch on my sport bike!
WOW! Every 3 hours? Are you kidding me? No Offense but that is crazy!
I'm so not changing my oil every 3 hours... Not even every ride.. I'm going to change it every summer, or maybe at beginning of summer, and end of summer.
For a racer, 3 hour oil change intervals are regular
Changing your oil only a couple times a year is just asking to have problems on any 'race' motor. Oil is relatively cheap compared to complete rebuilds, and is very easy to do.
Not everyone needs to change their oil every 3 hours, but you should still change it often at regular intervals. Dirty/worn oil doesn't lubricate as good, and will just let your engine wear out quicker.
I change mine every 5-12 hours or so on the dirt bike, and 500-1500 miles on my sport bike (because I do a lot of high rpm 1st gear riding on it)
edit: No offense.. but changing your oil 1-2 times a season is crazy imo.. But I guess everyone rides different hours, I put a lot of hours/miles on my bikes every year.
Using 'cheap' oil, an oil change only runs around $3-$10 for a dirt bike, only runs me $13 for oil and filter for my sport bike that holds 4quarts
