SM to kick start only
I know this has been talked about before and i have done some homework on this . The only thing I don't understand is the diod ( spelling) in place of the battery how does this work ? anybody have a pic having trouble getting my head around this
thanks
You mean capacitor. The capacitor stores charge in a similar sense to a battery (different physical properties though).
Diodes are "one way" points in a circuit. They only allow current to flow one direction.
I would expect to see both in the circuit in place of a battery. But I'm not that electric savy.
yes , capacitor I really need to read my notes before i post :banana:
so remove the battery and wire in a (12 volt ??) capacitor in it's place
sounds to simple
I am not familiar with this specific application but when selecting a capacitor there are a few things to watch out for. You will want to get one specd for more than 12v to have a safety margin. Something like 25volts or more should be adequate. Also capacity should be high enough to smooth the voltage, you will have to do some research on this one. I would assume an electrolytic cap will be used and if so you must observe polarity.
Jbw
Specifically, you'll need a capicitor rated for a higher voltage than the maximum supplied by the regulator; an over-charged capacitor can explode. Are you planning to replace the subframe and left engine cover to complete the build?
it way more than a engine cover and subframe to complete the swap.
crankshaft,flywheel,stator,stator cover,subframe,wiring harness,reg/rect (just a plug difference) etc.
most people just remove the starter clutch,plug the hole in the stator cover and install a capacitor.
the capacitor from the kickstart only drz isnt horribly priced as i remember.
that is my plan (most people part) so it won't be true kicker
I am going to use the kit from the TT store, so the kit comes with a cap
one more question wear do you put the capacitor
no it doesnt. you need to buy one seperately.
on the actual kicker it mounts on the subframe with a bracket.
you can put it just about any where though.
eddie thanks for the replys . I was not very clear when i asked about the location of the cap. I ment in the electrical system.
thanks
