Kickstart stop plate broken off
The bolt holding on the the kickstart stop plate has sheered off and the case is slightly damaged on my crf450r. I have done extensive searches on this forum and the 450x forum and have seen references to a repair that replaces the little spud on the case with a second bolt but I cant find the actual post that gives the details. If you drill out the little spud do you have to weld the back of the case to give you sufficient depth to tap a hole for a second bolt? When you drill this out does it go through to the outside of the case or does it go through to the gearbox? Any help in finding the post that gives details of the repair would be much appreciated.
I know this is an old topic, but did you ever get this figured out? I'm experiencing the same issues right now
