S Model Thermostat Failure!
I had a small leak around the base of the thermostat mount. I pulled it apart to investigate and found that the thermostat had froze and was completely nonfunctional. Luckily it had failed into the open position so I was still getting flow out of it. I am going to remove it completely and use the E model gasket. I don't live in an area where it gets cold enough to worry about my bike not warming up. Here are some pics of the failure.
Lucky. Usually tstats fail in the closed position.
YA lucky!! I have replaced hundreds of stats and only a couple of hand fulls failed open.
All put back together and no leaks. :banana:
Rock Monster, if I could ask, what about the noise? Are you OK now? What was it?.......your friend phillybeef...
