150/60 or 160/60 pilot power?
I'm ordering a new set of tires soon for my 05 sm and am not sure which size rear to go with.
Right now I have a pirelli scorpion sync 160/60-17 and it doesn't rub or anything.
Should I go with the 160/60 or the 150/60?
I'm getting a matching 120/70 pilot power front also to match.
Both will fit and both will work just fine. Many argue size
but I
prefer 160/60. I have used both sizes and have not noticed and down sides to th larger tyre. Is our rear rim 4.25in. Or a4.5in rim
here's a 160 of another brand
I've never road a with a 150, is there any noticeable difference? My bike came with that rear tire on it and its pretty much shot after about 3000 miles.
I hope your not expecting the pilot power to last longer! Its a pretty soft compound from what i have read. I got the road 2 and its harder in the center of the tire and softer on the sides. Will last a lot longer than the pilot power.
... Is our rear rim 4.25in. Or a4.5in rim ...
The SM rim is 4.5" width, and maximum profile width seems to be around 162mm, before the chain starts to rub.
I just fitted a 150/60-17 rear, 120,70-17 front. Handles and looks loverly...
No I don't expect it to last much longer then that. I killed the sides of my front pirelli dragon supercorsa sc2.. they are complete slicks. lol
Hey lynk what's up?? How's your ceramic coating holding on your pipe ?
The our was suposed to be your. But cool. At the right inflation on my rear it
comes out to about 164mm and only on hard cornering do it get slight rub. And I do mean slight. Almost 3k miles and is hasn't torn any piece yet.
Michelins tend to be on the larger size of the tolerance - I'd probably go with the 150 on that size rim. Check what they reccomend though.
The best tyre is not the biggest that will fit without rubbing. I'm running a 17" x 3.5" rim on the rear of mine, so I'm sticking with a 140 section. Works well. :banana:
I ride with a 160 power..no rubbing on the chain.
I've done 6K miles with it and still very good (40% life left at least)
But i ride them at 36psi(just like Sportbike) and they grip way enough.
Will try 32PSI to see if I notice a difference in grip, but I doubt so)....but with the recommend pressure: they don't last long.
ps.: I have no problem grinding the footpeg ont the track..not on the street..but very close to it :banana:
here you go.:banana:
hey whered you get that nice stand under your bike. And does it fit the sm or did you modify. Ive seen them that have a minimum of 11 or 12 " but i need a minimum hieght of around 9" how does yours work
im using a 150/70/17 pilot road 2ct and its working well.the profile is a little high and only rubs when i have the tire pressure low and cornering hard.i have 6000kms on it and it still looks new.mt next rear tire will be a 60 series profile though.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
