08 rmz 450 forks
I live in New Zealand and ride a 08 Rmz450 the I do club MX on and alot of cross country and enduro stuff. I'm a B grade rider and am 100kg geared up. I have problems with the forks feeling harsh on the small stuff, eg braking bumps tree roots and rocks.
I've pulled my forks apart and this is what I have
30
valve
30
30
30
30
30
20
29
29
29
28
27
26
26
25
25
24
24
22
plate
16
16
16
16
Does this seem right?? Any help please
Re counted and it seems to have 6 30s. If I remove one will it soften up the lower stroke?
I am not sure are there same settings in aus/nz bikes than in eu bikes but here are what is in eu fork
std
30-0.1 (6)
20-0.1
29-0.1 (4)
28-0.15
27-0.15
26-0.15 (2)
25-0.15 (2)
24-0.15 (2)
23-0.2
I suggest you to add couple of 30 face shims and cross over to 24. You can soften the high speed stack radically for example like this
29-0.1 (4)
28-0.15
27-0.15
26-0.15 (2)
25-0.15 (2)
24-0.15
22-0.15
20-0.15
18-0.15
as jusa showed, your fork has too little low speed already, you dont want to go softer on low speed, its allowing too much bleed and that makes it feel harsh.
That does make some sense now that I think about how it rides. What happened to th 30s in jusa stack. Should it be
30-.10 (8)
24-.10
then his stack
I rode in a six hour to weekends ago and it felt like the forks had been welded on the chopped out forest tracks.
Thanks for your help guys
30-.10 (8)
24-.10
then his stack
8-10 face shims. I think 8 is a good starting point.
Hey jusa,
Waiting on the shims to arrive but i picked up some fork oil today, got some maxima 85-150 5wt. Is this a good product?
Hey jusa,
I have never tested maxima but I think it's ok.
