TTR 230 2008 neutral to first
Hi everyone, i've been noticing once in a while, mainly when I first start my bike and go from neutral into first (with the clutch pulled in naturally) the bike gives a jerk forward... sometimes creating a stall. Anyone have this issue or know what this is? Thanks for the help in advance :banana:
it's normal, mine has always done it.mine is an 06. i just walk the bike after it is started, pull in the clutch, put it in gear and walk with it, it only lasts a couple of feet and won't do it for the rest of the day
What type of oil are you using and the weight? Is it cold when it does this? Does it do it all the time or when the engine is cold? Many bikes will do this in colder weather. Its the clutch not releaseing all the way. After riding awhile can you stop and find neutral? If you can, it is nothing to worry about. If it is just during the first startup, you might try a little lighter weight oil (make sure it is for a motorcycle) or let the bike warm up a little bit more.
Yeah. When the bike is warm enough to idle without the choke, bring the engine off idle a little bit and keep it there while you shift to first. There's no problem.
