xr 250r rear brake question??
hey guys, i have a question, a buddy of mine has an 85 xr 250r and it needs a new rear drum. we were thinking about converting it to disc. my quesiton is i saw that the 90 i believe xr250 have a rear disc can we just buy the whole setup rotor, caliper, pads, lines, hydrolics and master and just put it straight on his bike? or can we use a newer 250s rear brake setup and put it right on? thanks for the help guys!
Pretty sure you have to have to swap the whole swingarm and of course the newer bikes wheels and axles.
Is it a 17" wheel (my 85 350 is)? If so, then you'll be changing to 18" rear with the newer bikes. Higher seat height.
I have a 650L swingarm to put on mine, and a complete rear disk setup. Got $100 in those, but then I've got to scrap two 17" wheels (one set for street, so you really want the 17" and buy two 18" wheels (or 1 and a hub) to then build ANOTHER 17" wheel for the new setup. blahhhhhh
My rear drum will lock up the rear tire. As maximum braking force is just before the tire locks up, the drum can provide as much braking force as can be used. More power will not do anything to stop the bike any faster.
I got the swingarm/brake for the bling factor, because I've always got to be tinkering, but he reality is it's going to cost me $500 to do and I'm pretty sure it's not worth it in any logical sense. (JMO) :banana:
Probably just going to sit on the parts for now. I wanted to polish the swingarm, was part of it. Don't like my powercoated stocker as much now.
A method that I have used to compensate for a worn brake drum is to get the brake shoes relined by a local shop with linings that are thicker than stock.
I think it's possible but you would have to make some mounts for the caliper. Or you could just get the whole swingarm freom a newer bike. The 1990 modle is the first with disc brakes so I would be looking for one of them as it would be the most similar to yours. I'm have in the same problem but I never thought of converting to discs, I was just looking for a better condition wheel to put on.
  • Similar Content
    • By 661Bran28den661
      What’s up guys. Totally new here picked up an XR400R I live in the desert so I’m riding often and enjoy it. But I am having some issues with my  01 XR400R. I brought it out this morning for a putt and it seems to be choking up in the top of second. Like a bog an go bog an go. First seemed fine and third I didn’t make it high enough into the rpms to see. Before I brought it back to the garage. Yesterday I also changed the air filter back to an uni. I had seen the other one had a hole in it and the box was dirty gunned up and oily. I removed the airbox gave it a good clean out wiped everything down very well put a piece of screen over the snorkel Or where it used to be I should say. “Lightly oiled the filter.Also the spark arrester an tip for the bike it did not come with I ended up making one with a piece of flat steel and drilling holes. Whilst doing this. I found also a crack in the pipe. It almost sounds as like there’s a vacuuming or whistle? When revving.The first one I had made worked fine I had no issues. This one I am wondering maybe if it’s a cause of a little too much back pressure.So I’m assuming it’s either a Carb or exhaust problem. Or something that could totally be minuscule. Or major issue. Would definitely like some second opinions and any advice would be greatly appreciated. Thanks guys!
      TWISTIN THROTTLES & CRACKN BOTTLES
    • By ddickinson
      My lanky 14 year old boy started showing an interest in riding MX/Off-Road so I sourced the best beginner friendly, yet dirt worthy, bike I could find: an Ol' Honda XR250R (2004). So far I've replaced a few clutch levers and perches with stock parts. That's gotten old and I'm looking to upgrade to an ASV or Torc1 type fold-able clutch/perch brake combo. Went to purchase online today and to my surprise there were no such parts listed for the XRs. I saw plenty of CRF/CRF-X choices and they seem to differ depending on generation. Obviously I can use nearly any perch/clutch combo as long as the two match; but I was wondering if anyone knew which of these levers was closest to stock? Also, will the first gen CRF250X brake lever work on the XR? These may be stupid questions to some; but I'd rather ask a dumb question than drop money on an ASV brake lever I can't use. Thanks for any help.
      #xr250r#hondaxr
    • By TheLastByte
      Im currently in the market for an xr400r, and considering buying one that's had some heavy engine work done. The current owner claims to have bought it from a friend who's an XR enthusiast. The PO installed a big bore kit and high comp piston, as well as a xrs only pumper carb, rsw triple clamp, aftermarket clutch, street lights, and a whole bunch of bling.
      My main concern is the effect the upgrades will have on the engine's longevity. How much quicker will I be going through top ends with the setup on this bike as opposed to a stock setup, and should I be worrying at all about bottom end longevity as well? I wouldn't mind having to eventually redo the top end, but I don't want to deal with a race bike type top end rebuild schedule on an XR.
      Is there anyone here who's running a bike similar to this one who can give some advice?
    • By Ralph303
      I have a 2001 Honda XR400R. It has a whirring/grinding sound in the lower end and a vibration in the top end. I pulled the valve cover and everything looks good. Decompression lever looks to be in order. Anyone know where I should start looking or just rebuild the whole engine. Ballin on a budget, but really love this bike. It looks like it’s new otherwise. Oil was jet black and thin. Thanks in advance!
    • By junglePIG
      Hi, I have an Xr250r with a buckled/ wobbling front wheel, after trying to true the rim i have broken a spoke.
      I am wondering if it is possible to lace any 36 hole aftermarket rim to the oem hub, also will i need to buy an xr250r specific spoke set. also could i take a 36 hole rim from another front wheel and lace that up???? thanks
