I need a SM model fork compression needle, please help if you can
K, so a friend that builds sport bike forks regularly offered build my SM forks for me. He neglected to turn the adjuster out on the top compression needle.One went fine and one went fork had an issue . The other needle tip broke when he attempted to turn it after assy since there was too much preload on it after assy. If you have a sparetop valve assy for an 02-to current top valve assy or needle or a direct link to an purchae point...not RON Ayers, I would really appreciate the help. Thanks in advance.
Thanks for readings.
Edited by JPRaceCraft
sp
