shifter linkage
Hey there, I picked up an 06 back in October for a steal of a deal and got to ride it 2 times before the snow fell. Today we studded up and hit the trails but about 1/2 hour in I tried to shift into neutral at a stop and it would not go. I heard a bit of a grinding sound when I released the clutch (not bad though) and then the bike was unable to shift.
It is in second gear and there is still spring action up and down but nothing engages. The bike rides fine I just could not change gears (called it a day).
Has this happened to anyone else. Is the linkage accessable from just behind the clutch ect or will I have to dig into the engine.
Any help or advice would be greatly appreciated.
Michael
Some early 06s had problems with shifting parts. I cannot remember the details. Search old 06 postings. eg. "Detent bolt" in the FAQ.
Thanks for the reply. I just did about 2 hours of reading and it soulds like the detent bolt or nut issue that appears to be be quite common.
I will open it up tonight and post my findings.
Later
Michael
EASY fix man i have an 06 also and i had a lil get off last summer and i couldnt get neutral or any gear past 2nd gear. Tear ur clutch cover off and pull the clutch apart and behind that u will a linkage arm that has a groove in itand actually engages the shifts runs all the way across to ur shifter sounds like it cracked just like mine did mine had a million little pressure cracks in it and one big break so idk if this was all from one impact or just from over time. Bout 30 some dollar part and u should be good to go put her all back together and rip
Hey there, so I found at least part of my problem. This part is off the end of the shaft. I got held up as I did not have a big enough socket to get the clutch basket off. Tonight I will be able to see if there is any other damage.
While it was apart i took out the oil screen and was a little shocked to find this many metal shavings and tiny pieces. A little scarry.
Sorry for the fuzy pics.
thats the exact same problem except min actualy broke off. I got it apart and ordered up a new shaft. At one of the breaks I noticed that is was bright blue (like from excessive heat) and when I got the shaft out I realized that the heat was from where the arm is welded to the shaft. Maybe too much heat weakened the metal or something.
Anything else I should do while it is apart other then check the torque on the detent nut.
Also, so you guys change the gaskets whenever you remove covers etc? Or reuse them a couple of times.
Thanks
dammmn thats alot of metal on your oil scavenge screen, ouch
Thanks
yea wow this must be a common problem with the 06's then because mine was all blue colored from excessive heat also and even the new shaft you will get in will be all blue from heat so idk i beleive that end peice that broke is magnesium welded to the steel shift shaft but i could be wrong. When u put it back together just manual shift it through all the gears before u put it all back together just to make sure it didnt mess anything else up. Mine was fine so i would assume you would be good to go also but just to save yourself a headache in case
All it means is that you were tap dancing on the shifter like a champion. Easy repair. The hardest part is getting the 30mm nut off the center clutch. I needed an impact with 120psi. Those japanes ladies are strong!:banana:
  • Similar Content
    • By tanner_shany24
      Hey guys, I have a 2012 KX450f and it is giving me major issues. I will give you a run down of the history of it. I bought this bike a few months ago and have only ridden it really once, yes once! When I bought it everything seemed to check out, it ran fine, started fine, sounded fine, so I bought it. Took it out to ride and the first hill I hit it got really hot and overheated like a SOB and spewed coolant everywhere. I thought to my self maybe it was because we were riding trails slow before so maybe when I actually got on it it got too hot. After that though, it began to overheat every 3 minutes no  matter what, I would ride it for 3 minutes, and have to stop to let it cool down because I was scared I was going to melt the top end. Got home and started inspecting, found out that oil and coolant was mixing both where the oil is supposed to be and where the coolant is supposed to be. After some research I found that the 2012 450 had head gasket issues. Assuming that was the issue, I took the head off and got it resurfaced (it was actually decently warped) and put new gaskets in everything top end related. Piston and cylinder looked brand new by the way. So I put it back together, started it up, and it instantly started spewing coolant and oil mixed out of the crank case breather hose. Like literally as soon as i started it and it would make a puddle on the ground in 10-15 seconds. I'm at a loss here, brand new coolant and brand new oil, brand new head gasket and resurfaced head, and it instantly started doing the same thing again? What could it be? Is it worth my time or do I part the bike out? I have put way too much time into this bike to want to tear back into it again unless it is something cheap to fix, if not I am going to post it on craigslist and let someone else deal with it. Overall this whole experience makes me want to go back to a 250T! XD
    • By Sam Mclean
      Hi new to this site.
      Ive just bought a cheap kx450f with what i thought would be a minor issue.
      I was told it was only running with the choke on and i thought easy fix, just a blocked jet. So i pulled it apart as must of the person before me and i find a broken soround thing that the plastic case sits on around the pilot jet. So i appoxy that back on unblock the jets and clean it all out, put it back together and now i try starting it for the first time and see the fuel dripping as it was when i bought it. When i look closer i see it is seeping from what looks like a crack in the float bowl. Ahhh
      So my problem is. Looking for a cheap carby might solve all my problems or just a float bowl at worse case. Now i can find many kx450f being wrecked nearby so im wondering are most 450 carbys the same? Will one of a yz450f work?
      Can someone please help
    • By Sam Mclean
    • By BadcaseofTB
      I missed tracking where this little top hat came out of in my 2011 kx450f. Was thinking clutch or right side engine cover. Any help would be appreciated I can’t seem to find it in the manual.
