Moving while clutch is pulled!
I washed my bike a while back and after that I could never get it started. Changed spark plug and no help, have good spark though. The other problem I am seeing is that if I put it in 1st, pull the clutch in, and attempt to start it the bike will actually try to move forward and make a not so pleasant cranking sound. Once again this didn't happen until after I washed it and it wouldn't start. Been like this for a while and haven't had a chance to fix it but ready to get crackin. Any ideas?
What type of bike,E,SM,S?
LIke others have asked, Is the oil Contamiated with gas or water?
Did you Try Spraying carb cleaner or starter fliud in the carb?
Is the vacume line on at the petcock?
Do you have fuel in the carb bowl or water?
furst thing is to change the oil
2nd is to get fresh gass in it
3rd make soe the battery is fully charged
4th maybe reay squerting a little oil down the sparck plug hole ( helps the rings seal )
5th hav e you done the lock-tight fixxes ?
Yeah, clutch is dragging. Do what they said.
A smidgen of drag yes, not like he is describing though. I well adjusted bike will not lurch forward in first if you thumb the starter with the clutch pulled in...
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
