Worst Day on the 450x Ever
Just got home from the D38 Hare & Hound. Myself and the 450x have had better days. At about race mile 30, I lost it on a snotty mud hill and my day deteriorated from there. The mud was so gooey and sticky that it just kept accumulating to the point where I couldn't even push the bike. Front and rear brake pads were completely toast. Mud and zero brakes don't go well together.
Having strained my already sore wrist and now left with an entombed and brakeless bike, I called it a day. On my way back to the pits, I underestimated the depth and strength of the current of an arroyo on the "dry" lake bed and found myself and the 450x entirely submerged in about 4' of swiftly flowing water. I was completely under for about 5 seconds, when I was able to get my footing and stop us from flowing down with the current. Somehow I was able to hold on to the bike and pull it out of the water. At that moment, I probably could have bench pressed 500 pounds because that's what it felt like I was working against.
The bike immediately hydro-locked and was done. Within 30 seconds or so, the water had drained past the rings and I was able to slowly crank it over, but he was toast at this point. I had to walk 8 miles back to the pits through knee deep water, mud and rain. I was so exhausted by the time I got back to the pits, I nearly fell over. We eventually got a Rhino to pull me out. The rear wheel was so locked up from all the mud, we dragged it about a mile before the rear wheel finally broke free.
(Rotor guards are not a good idea in very muddy conditions, I discovered. The mud was not flinging off either. The inside of my front fender was clean. Lesson #2: hard terrain tires are not the right choice for mud.)
So my question is - besides pulling out the spark plug, cranking it over until my leg was numb and spraying ample WD40 down the hole, what more can I do to protect this thing from any further damage? I drained the engine/tranny oil - which was nothing more than grey water. I sprayed contact cleaner up into the transmission and oil drains as well.
Someone told me manually cycling diesel fuel through the motor and transmission is a sure fire way to remove all the contaminants. Does anyone have first-hand experience with this?
Edited by Justin Hambleton
Deisel or karosene same same. Fill and flush both sides, circulate and drain. Fill with cheap oil, start, warm it up, and drain again. Then fill with your normal oil and you'll be good to go motor wise unless the rod bent. Brakes and clutch as well as CS seal, chain, and wheel bearings need attention too. I know this much because I did the same race today on my 450R and trashed the brakes and clutch. Mud packed in ways I never thought were possible. I must have crashed at least 20 times and kicked that thing about 10,000. Had to stop three times and clear mud with sticks. No goggles for 55 plus miles and no gloves with snotty mud on the grips. No fun with hypothermia especially but I got my pin galldarnit. I never saw a 700 pound 450 R until today. Rough race is an understatement.:banana:
diesel is the way to go.it's non corrosive, has lubricating properties and displaces water. fill it up in both sides, roll it through and drain it. let it sit without the drain plugs overnight. fill it with cheap detergent oil and run it til warm and drain it again. don't forget to change that filter out each time you change fluids.you may want to do this several times. this may sound strange but you need to clean the carb out too. this would include taking the slide out. you will be suprised how much crud you'll find in this area. you gotta lot to clean so be thorough. good luck:banana:
With the bike in that condition I would start with cleaning the bike of all external mud,pulling the spark plug and making sure all the water is out...spray some sort of oil into the cylinder to prevent any water damage. Clean the air filter of course. I would fill the engine and tranny back full with new oil and filter. Probably will have to drain the tank and the carburator...So with new oil, New Gas, and clean bike, I would get ready to start it. Put a battery charger on it so it will crank fast with out killing your battery. It will be very difficult to start. Once you start it i woul let it warm up to operating temperature. After it is hot i would shut it off and drain the oils again. Let it drain completely. after it stops dripping I would put the drain plugs and fill it back up..I would then go for an easy ride to keep an eye on it.
Power washer. My son washed mine and it took two hours. I took stuff off like the CS guard and bash plate so we could wash that crap off. I'm supposed to ride tomorrow but I think I'll work on getting a new bike instead. There's mud and then there's D38 mud. Never in my like have I seen such slippery yet gooey shit. Unreal. I feel for you brother.
Did you finish? Because if you did, my hats off to you. If you remember the 2008 Daytona Supercross - the first loop was most definitely the off-road version of that race and that's no exaggeration. But, I'm no Kevin Windham. I was actually doing fairly well up until RM 30, when my brakes were gone. My strategy was to push ahead on the second loop. I'm bummed I didn't get to enjoy the fun there.
Thanks a ton for the tips. As soon as I got home, I removed the tank and seat and washed all the mud off the motor. I removed the spark plug and kicked until the blow hole stopped. I drained the oil and left the plugs out to drain overnight. I sprayed WD40 down the spark plug hole and kicked it over. I repeated this 5 or 6 times. It's not a good idea to stand over the spark plug hole and kick it over, btw :banana:
I'm going to take it to a do-it-yourself car wash tomorrow to get after the remaining mud, which there is plenty. The mud is better there than on my driveway anyhow :banana: I sprayed Simple Green all over the mud to keep it moist.
I'm planning to tear it completely down once it's clean. I just can't imagine riding it again until I've been able to go over everything. Suspension is going straight to Precision Concepts (needed service anyway), carb will get serviced, drain fuel, grease everything and button it up. I'm actually tempted to send the head to AS for a port & polish. I'd feel better about seeing the cylinder, piston and ring gap as well (just out of curiosity after 70 hours).
One thing I realized is the water we were submerged in had a lot of dirt sediment - it was light brown. I'm concerned about this being in the motor so I'll probably be excessive with cycling diesel fuel and motor oil through the engine and tranny. Am I being overly concerned here?
Honestly, it's days like this that make me not want to race or ride motorcycles again. But, I'll sleep it off and be ready to ride tomorrow :lol:
Funny, but I know what you mean. Don't ask me how I know. :lol:
You're bike will be fine after some TLC, Justin. I finished the A loop in just under 4 hours:lol::lol::lol:. My "problems" began on the mud fest out of Painted Gorge for the most part. I'll have to completely tear down the bike though. Brakes and clutch are shot and it time for a piston. I survived the nightmare kicking that thing a zillion times and will be limping around work today. Crashing in the mud stretches things that should not be stretched:lol::banana::banana:
That sounds like a great idea!:banana:
Wow!:lol:
That does not look like fun. I'm glad you guys are ok. Looks like both of you have your work cut out getting the bike back into shape.
Very good idea to have a look inside at 70 hours especially after that fiasco yesterday, Justin. It's time for a piston anyway IMHO.
It was insane, manx. I would venture to say there was over 50% DNF (without knowing the results). The rescue guys said it looked like a yard sale out there. It was carnage from the bomb all the way through. I won't be riding in those conditions ever again. I put the pin in my little pin case last night smiling because I was thinking about Dewey Belew out there at Check 2....I've not seen him race in the last couple of years but he's one of my all time favorite desert racers. It was awesome to see his smiling face and get a pat on the back by Dewey. He said, "Way to go! You're halfway home!" What a liar.....It was like RM 20:lol::banana::lol:
Insane is an understatement !!! Sounds like a wicked excursion for sure. I have never attemted to ride in those conditions and from reading the above experiance never will!!! I'm glad you made it Cubera and Justin hang in there clean her up and out everything will be fine just be happy you guys are able to ride still waiting for the snow to go away here!!!! Just think of all the time you get to spend with your baby caressing her and all. LOL!! Good luck with the clean up you two
Holy crap!
We had a great time in the "dry" high dez.
Thats a switch though.
Lowdez=wet
Hidez=dry
Good luck Justin with the swamp goo.
Its a Honda, It will be as good as new.
Mine was begging me for a full teardown/maintenance/suspension also.
First... Welcome to D38 Justin!
Second... whoever said D38 was easy (easier than D37), needs to run a rain race
Third... Holy shit.. thats some mud! (I hate mud, as it ruins the cleanliness of a bike - staining and getting into bearings, and seals)
Sounds like you got out, and made it home. Still sucks!! I feel your pain. We've gotten trucks/trailers stuck in that mud when it's raining and someone decides it's "time to get out of here... before it gets worse" type of thing. Always best to wait it out.... it dries within a day or two (enough to get out anyway).
I'd tear that bike down, re-lube every seal or bearing and do as they said by flushing the motor with diesel. In fact, I'd be sure to flush it a couple times right side up, and then once on each side (laying the bike horizontal) and once upside down. There's too many caverns inside that motor that can hold small chunks of dirt and rock, and can cause harm in the future.
I've had a similar experience, but it was in Baja... and I was caught in a flash flood... but on a (Baja race ready) Bomb DS650 that I used to have (no kick start), and a buddies KTM 525. It was KNARLY! Lightning 100' away, 2-3" of water on the ground, slippery, and we mistakenly rode into a water crossing that looked shallow... but was at my neck level when I rode the quad in to cross. SCARY stuff. We made it ourselves 280 miles that day, but I took a shower using the radiator water spicket at the Valley Trinidad Pemex (with full gear on!). :banana:
I missed my 450X yesterday more than ever. I seriously thought I might not make it out of there between RM35 and 45 and then the last couple of miles over the "dry lake" which has torrents of muddy water and deep pools of standing water. It took me 4 hours to make 56 miles and about half that time was spent trying to clear mud or even pick up the bike. Then to get it kick started finally with a mud packed boot only to crash again in a short distance was rough. In hind sight, it was one of the toughest situations I've even been in on a dirt bike....maybe even the toughest. Hats off to you too, Justin.
We were pitting in 92 or 93 near Valley T for Donoho when the skies unloaded.
Thought we were going to get washed away. The wash crossing about 500 ft away was a raging river and race TRUCKS were washing down.
Heard Sal get on the radio and state, "Every man for himself".
Makes you feel wanted.
I've heard your accounts first hand of the time you got stuck in the flash flood in Baja, JJ. That's much scarier than what we went through yesterday IMHO since there was someone within hollering distance the whole race except the last 20 miles or so. I also knew sooner or later I could get to the truck and crank the heater on if I could just keep moving. It became a game of prayer, self talk, and survival. The reward is knowing even highly skilled fast guys have respect for the shared experience with us mere mortals.:banana::lol:
Honestly, it's days like this that make me not want to race or ride motorcycles again. But, I'll sleep it off and be ready to ride tomorrow :banana:
OK, I slept it off. I'm ready to ride again :lol: I've got two weeks to get it race ready. Let the fun begin!
TW... been there too! And seen race trucks being swept away. I've also seen them sit and wait, while being drenched. Crazy "race" stuff for sure.
Coob... I hear ya. That mud will swallow ya whole. Adding to it, two buds of mine got stuck in the deep sand (or wash quicksand) three weeks ago at Soops area, took them 4hrs to get a bike out. It's now down to it's frame... as there's sand in the cylinder and crankcase.... even inside the swingarm!
Crazy stuff out there in the desert!
OK, I slept it off. I'm ready to ride again :banana: I've got two weeks to get it race ready. Let the fun begin!
BRAAPPP!!
http://www.thumpertalk.com/forum/showthread.php?t=487318&highlight=turned+my+bike+into+submarine+a
Damn brutha sorry...that sounds like hell on earth. I have submerged my bike too but my experience wasnt nearly as bad as yours....keep your chin up you'll get'r going again.
My bike was completely full of sand and water to the point of being hydro-locked I was surprised at the amount of sand I got out of the tranny.
  • Similar Content
    • By mikesbaron
      2005 CRF450X:
      Stalled my bike on an uphill single track, tried to start it and it would not start. Pushed it off the mountain solo (took me 3+ hrs to cover 3.5 miles!). At home tried spark plug to frame to see if I get a spark and nothing. Not even on multiple plugs. I did see what I thought was a super weak spark for about a millisecond and then it was gone, no longer to be seen.
      Before I pay for a new coil, how can I check it? What other pieces on this thing should I be checking for? I checked all the wiring and the main fuse near the battery. I have horn power and rear LED taillights working just fine. Bike wll not start with e-start or kick start of rolling it down a hill.
    • By TheVolta
      2006 Honda CRF450X
      Extremely clean and well maintained 2006 CRF450X
      oil changed after every two rides. Starts right up with no issues.
      Upgrade parts list:
      IMS 3.2g Extended Gas tank
      Noguchi Seat (Same seat used by HRC Dakar bikes)
      Renthal Fat Bar
      FMF Powerbomb Header and Pipe
      Highway Dirtbike Guards
      Renthal Clutch/Hotstart Intellilever
      Renthal Brake Intellilever
      Honda Airbox Mod
      Speed Cell Lithium Battery
      Acerbis Skid Plate
      Acerbis
      EK Did Chain and Brand new Sprocket set
      R&D Flexible Carb adjustment screw
      07+ Headlight Conversion
      Black Fork Guards
      OEM and JRC Plastics
      Spare parts included / original tank / New Rear fender/ OEM Exhaust/ Original Sprocket set/ OEM Bars / Filters
      **Willing to adjust price without OEM Handle Bars in place and no HWDB Guards. **
      Paypal and Venmo Accepted.
    • By Colin Greis
      ALL HELP appreciated.
      Bike: 2006 CRF450x Supermoto
      Back story: about 3 weeks ago went down on the pavement the bike landed on the left side, nothing broken other than bent shifter and a broken foot peg bolt. [to what I can see]. Rode home the bike (in pain) the bike sat for about 3 weeks while I let my body heal and worked on getting out the broken bolt and replacing the bent shifter.
      [Bike and Body ready to ride again]  The following ensues.
      Day 1: Started the bike up no problem using the electric start (seemed little bit louder than normal) rode down the street after about 5-6min of riding bike started to bog and wanting to die after slowing down for a red light the bike died. Would not start electric start or a kick, had to do the walk of shame and push the bike out of the road traffic. Got the bike started back up 5 mins later with choke on and on the ride home the same thing happen once more.
      That night did a oil change and looked at the coolant [ full to the brim]
      Day 2: After thinking about it... thought maybe my idle screw messed up from the crash. started to messed with the idle and the fuel screw. This seemed to some what help and got a quick 15min ride in no problems running a bit rich maybe had some backfires.
      Day 3: Added slip on FMF muffler that I ordered to replace the other crappy aftermarket muffler. took the bike out side and the electric start didn’t work just clicked away.. the bike started with the choke on using the kick start. [did not want to start as easy as it always does AT ALL] bike idled high for 1 min while I tinkered with the idle and fuel screws again, noticed smoke coming from the water pump area [front lower right] a plastic tube was touching the water pump maybe causing the smoke. turned off bike immediately. after the bike was off a small bit of white smoke was coming out the exhaust [not like oil smoke like (fire-ish) smoke maybe due to the brand new slip on.]
      So... what does everyone think whats my next move.
      Did I clog up my radiator when I a crashed?
      Break my water pump?
      Is the bike overheating?
      mess up my fueling?
      Please let me know! thank you.
    • By Bryan Bosch
      FOR IMMEDIATE RELEASE
      Honda Broadens CRF Lineup with Expansive New-Model Launch
      Largest performance off-road release yet includes new models for diverse applications
      IRVINE, Calif. (May 23, 2018) – During a recent “CRF Collective” unveiling ceremony at Fox Racing headquarters, Honda announced its most far-reaching range of performance off-road models ever, expanding the group by three and significantly improving the four returning models. Leveraging the brand’s unparalleled experience in the manufacture of dirt bikes, Honda’s performance off-road lineup now includes CRF machines for riding applications including motocross, closed-course off-road, pure off-road, and even dual sport.
      All seven models are based on the platforms of Honda’s revolutionary motocrossers, the CRF450R and CRF250R. Those two machines return for 2019 but with important updates, as does the closed-course off-road CRF450RX. In addition, Honda is offering a factory-replica version of its full-size motocrosser called the CRF450RWE (“Works Edition”). The trail-ready CRF450X is entirely new for 2019, and it’s joined by a road legal CRF450L that enables customers to connect trails via asphalt. Finally, Honda is also introducing an all-new CRF250RX closed-course off-road machine.
      CRF450L Dual Sport
      The trails are calling, and the all-new road-legal CRF450L answers, expanding customers’ off-road possibilities by enabling access to the best riding trails, even when that means connecting them via asphalt roads. Street legality is achieved via features like LED lighting, mirrors, and a dedicated exhaust system. Equally at home in the woods or desert, the CRF450L has a wide-ratio six-speed transmission for maximum adaptability, while a lightweight, 2.0-gallon tank offers great range. Compared to the CRF450R motocrosser, crank mass is up for tractability in technical conditions, where a large-capacity radiator keeps things cool.
      Color: Red Target Price: $10,399 Availability: September Info: https://powersports.honda.com/2019/crf450L.aspx >>> More pictures, video, specs & discussion on the 2019 Honda CRF450L <<<
      CRF450RWE (Works Edition)
      For the 2019 model year, you don’t have to be Ken Roczen to enjoy a CRF450R with factory enhancements, as the new CRF450RWE features a number of upgrades based on the bikes in the Team Honda HRC race shop. Rocketing to the top step of the podium through the use of a specially designed cylinder head with hand-polished ports, Yoshimura titanium slip-on muffler, and special ECU settings, this new model offers increased low- and mid-range torque. It also features the same graphics as Roczen’s No. 94 race bike, including a Throttle Jockey factory seat cover. Upgraded black D.I.D LT-X rims are included, along with black triple clamps and a gold RK chain. Titanium nitride-coated fork legs and an updated, titanium nitride-coated shock shaft increase traction and bump absorption.
      Color: Red Price: $11,499 Availability: August Info: https://powersports.honda.com/2019/crf450r.aspx
      CRF450R
      Already the industry’s top-selling motocrosser and the winner of the 2018 Daytona Supercross at the hands of MotoConcept’s Justin Brayton, the CRF450R receives a number of important updates for 2019. Better engine performance is achieved through a new combustion-chamber shape, as well as improved over-rev characteristics through a refined oil-management system. The frame and swingarm have been revised for optimized rigidity and weight reduction, while the braking system has been updated with a lightweight front brake caliper featuring a large-piston design. As a result of the weightsaving measures, the CRF450R is 1.76 lbs. lighter than its predecessor. For added performance and increased comfort, the 2019 model features new ECU settings, HRC launch control, a Renthal Fatbar® handlebar and adjustable handlebar position. Black rims and redesigned fork protectors are also new. This is how you convert the “Absolute Holeshot” into moto wins.
      Color: Red Price: $9,299 Availability: August Info: https://powersports.honda.com/2019/crf450r.aspx
      CRF450X
      Having featured heavily in Honda-mounted teams winning 20 of the last 21 Baja 1000s, the CRF450X gets a complete overhaul for 2019, based on the modern CRF platform but with off-road-appropriate features. A true off-road machine that’s ready for racing or trail riding, this model features a headlight, taillight, and side stand, as well as an 18” rear wheel and lightweight 2.0-gallon fuel tank. For maximum versatility in challenging terrain, the CRF450X also features a 49mm Showa fork with dedicated settings, wideratio six-speed transmission, and higher crank mass than the CRF450R.
      Color: Red Target Price: $9,799 Availability: October Info: https://powersports.honda.com/2019/crf450X.aspx
      CRF450RX
      Currently campaigned by JCR Honda’s Trevor Bollinger and Trevor Stewart in GNCC and WORCS competition, respectively, the CRF450RX inherits the same performanceenhancing features of the 2019 CRF450R, including an updated cylinder head and refined oil-management system, while still featuring off-road-specific features like a 2.2gallon resin fuel tank, 18-inch rear wheel, and aluminum side stand. Suspension is specially tailored to the CRF450RX and uses low-friction fork oil. For added performance and increased comfort, the 2019 model features new ECU settings, HRC launch control, a Renthal Fatbar handlebar, and adjustable handlebar position. Black rims and redesigned fork protectors are also new.
      Color: Red Price: $9,599 Availability: September Info: https://powersports.honda.com/2019/crf450rx.aspx
      CRF250RX
      Based on Honda’s successful 250cc motocrosser, the all-new CRF250RX joins the CRF450RX as a weapon for closed-course off-road competitions throughout America. Equipped with a larger-capacity, 2.2-gallon resin fuel tank, 18-inch rear wheel, and aluminum side stand, the RX makes quick work of challenging situations, its dedicated suspension and ECU settings helping the rider work through even the toughest trail sections. As with the CRF250R, HRC launch control, a Renthal Fatbar handlebar, and black rims are standard.
      Color: Red Target Price: $8,299 Availability: September Info: https://powersports.honda.com/2019/crf250rx.aspx
      CRF250R
      Newly introduced in 2018, the CRF250R has seen the GEICO Honda and TiLube Honda teams earn multiple wins in AMA Supercross and Arenacross competition, respectively, while also achieving success in amateur national races. For 2019, the model is revised with increased low-to-midrange engine performance for improved corner exiting. Inspired by the factory version, the Double Overhead Cam engine features updated cam profiles
      and intake- and exhaust-port profiles, a 50mm shorter right exhaust pipe, and a 2mm smaller throttle body. Riders can select from three engine modes for ideal performance depending on conditions, while HRC launch control has been adopted for improved race-start performance. A Renthal Fatbar handlebar sits in a four-position-adjustable top clamp, while the braking system has been updated with a lighter, CRF450R-inspired caliper with larger piston for optimum braking performance. Black rims are standard.
      Color: Red Target Price: $7,999 Availability: September Info: https://powersports.honda.com/2019/crf250r.aspx
      CRF150R / CRF150RB
      Raced by Amsoil Honda hotshot Hunter Yoder on the amateur national circuit, Honda’s smallest motocross machine returns for 2019, featuring a Unicam four-stroke engine thatoffers a spread of ample, useable power and torque across the rev range. Suspension duties are handled by Showa, with a 37mm inverted fork and Pro-Link rear link system. In addition to the standard version, Honda offers the CRF150RB, which features larger
      wheels, a taller seat, a longer swingarm, and more rear-suspension travel.
      Color: Red Target Price o CRF150R: $5,099 o CRF150RB: $5,399 Availability: August Info: http://powersports.honda.com/2019/crf150r.aspx
      ABOUT AMERICAN HONDA
      American Honda Motor Co., Inc., is the sole distributor of Honda motorcycles, scooters, ATVs and Side-by-Sides in the U.S. American Honda’s Motorcycle Division conducts thesales, marketing and operational activities for these products through independent authorized Honda retail dealers. For more information on Honda products, go to powersports.honda.com.
    • By moneypit
      Hello all. I just wanted to get some other crf450x owner input on something my brother noticed on my new bike. So this is on a newly purchased 2017 crf450x with about 4 miles on it currently. while riding around with my brother in my inlaws yard he pointed out that the head pipe was starting to glow red. I'm wondering if this is because the bike is new and is a bit hotter due to breaking in or if there is possibly a different issue going on with this new bike. Most of what i read suggests a lean issue presenting it self with the carb. i just installed a trail tech vapor kit on the bike but i doubt that would influence anything.  Any help would be greatly appreciated. hopefully this wont abort our first trip out to go ride it this weekend.
