Michelin AC10 tires
:banana:
anyone have experience with these tires? They are a dualsport knobby. I am thinking about buying some to replace my old tires on my 1997 XR600. They look like a great tire to me, and are DOT approved, so I can ride on pavement legally(my XR is plated, its easy in Idaho). Lots of the places I want to ride this summer, I could just ride there on the county roads or highway, so I will be putting in some slab time, but 80% of my riding will be various trails and hard packed dirt roads, like Forest Service roads. I would also like a tire that deals with rocks well, as Idaho is rocky. Somehow I always get into rocks sooner or later, the buggers. Any thoughts greatly appreciated.
Hi
I have a 1996 xr 600 and it came with AC10's and I didn't like them, OK in dry conditions, but on hard slab rock and on the road the front would try to let go with out warning, using full mx tyres not a slip anywhere.
But I do live in wet old Wales UK, as a road legal tyres they do have a good tread pattern.
I use em on my 97 XR600r and like them. I sometimes commute 100 miles roundtrip to work, and they do fine on the frwy @ 70+mph, and do pretty good in the dirt too. They wear great too. Im actually using a D606 on the rear (AC10 frt), but prior to that, Ive gone through 3 rear tires. Pretty good tire, I had 'O' issues with them
Thanks for the replies :banana:
What are "O" issues? I was actually looking at putting a D606 on the rear, its my first choice, but it does not come in the 110/100M-18 that is stock. What is your setup? I am very intrested, as I would definitely consider changing things up so I can use this tire. I want my XR to be the best it can be, and am willing to spend the dough to get it there.
The AC10 Mitchy is a decent tire for dry conditions,the front is a little narrow for a big thumper though.
What would you recommend? I want DOT approved if I can, but I think that I may have to go MX to get the kind of off road performance I need? I was looking at a Dunlop 952 for the front, but they are not DOT approved :banana:
Meaning they were very good with no problems. No flats, pinched tubes, good traction on/off road and good wear = 0 issues.
I just happened to get the D606 130/90 18 (rear) last time to try something different> It aint bad either.
My set up is pretty much a stock plated 97 XR600r. It has: Clarke 4.7gal tank. Pro Taper CR high bend bars, Works Connection frame guards & clutch perch w/hot start, 91 CR500 USD Frt end, Excel rims frt/rear. Talon hub rear. Stock rear shock. Old Baja D HD chain guide, Billet rear disc guard w/brake mount, Engine 'uncorked': UNI filter, jetting, Pro Circuit silencer, Baja Designs kit w/custom HID headlight from 08 Infinity G35. Im using Garmin 60cx GPS for speedo/odo. More info in 'my garage'
