Running wide in turns?? Husaberg?
I have a 2010 Husaberg 570 that wants to run wide in the corners.
I am running 113mm sag as apposed to the 105 recomended, and have dropped the forks to the second ring to compensate. I have 2 turns of preload (took one turn off) on the forks and have tried to slow the rebound by 4 clicks and compression a couple as well. I like the way the bike handles everything in a straight line and flicking through the trees, but it just seems to want to run wide in the turns and climb out of the ruts. Just cannot seem to get the front to staydown in the turns.
The 09's came with 19mm clamps and the 10's 22. Should I try a set of those? as I have acces to them, or is it more of a case of changing riding style to compensate for the lack of weight over the front due to the new engine config?
Any thoughts??
i would try the different offset, its a no cost option that could work.
Hi Fitzy. You sound passionate. I think your engine config has nothing to do with this.
As mog said, try the 19mm offset. Especially since you said it'll cost you nothing. But to get the most out of them, I think you could also try increasing the initial turn in of your bike. So you might need to raise the rear or lower the front. Stability at speed should improve with the 19s.
If climbing out of ruts, then in my experience that can be because: (a) something (or someone) is preventing enough chassis lean of the heavy bike into the turn, and if not laid over enough on entry for the speed and radius then it simply has to straighten up (:banana: the fork rebounding too quick or compression too slow, © just too much rear sag. If not a well defined rut it could be (d) just a poor choice of front tyre.
Maybe slow the fork rebound even more but dont forget to speed up the comp. Or find a smooth flowing rut without aggressive braking on entry to take the dampening settings out of consideration. Maybe the lack of weight on the front is not the engine config, but just the 7mm extra sag you have and your fork height/preload changes are not enough to compensate. If you have the rear setup relatively low just for stability, then maybe you are getting stability via the wrong method and incorrect fork damping is causing headshake for you if not using lots of sag.
Just curious, what is the steering trail on your bike? 19mm offset would be a lot of trail on the Jap bikes. I am at 22 on my KX450F and I've tried 21 and in most conditions the front feels just a bit too slow to grab.
Thanks bloke. Been out the shed today and reset the sag, and put all the clickers back to stock and going to start again. Standard offset is 22 and I like it. Speaking to a few guys and bikes are very sensitive to body position, so I might just have to move this old ASS of mine around a bit more.
Going out tommorrow night so I'll report back. Don't want the 19's if I can help it. Gonna try another front as well later. If it makes any sense, I like the way it steers, but not the way it turns:bonk:
Cheers
Yes that makes sense. I think turning = steering + lean + traction. Steering alone certainly aint turning the way I feel it. Good luck, and you are welcome.
The 22mm clamps make everything better on the Husabergs, it makes the bike more stable at high speeds and the sterring is less agressive while cornering.
Never rode the 570 but i normally ride a 450 and a 390 both 09 and 2010 models and i can feel well the diference betwen them.
In my opinion you should put the correct sag and play a bit with the forks in the triple clamps.
The suspension as to be revalved in those bikes even for the weekend warrior, when a proper setup is installed a miracle happens. :banana:
I've played with offset changes a lot on both my 450F and my pitbike. I assume you were referring to an increase on the bergs from 19 up to 22mm.
When increasing the offset, I dont experience what you described at all. When decreasing the offset it increases trail. I feel what I expect, which is slower/delayed steering (although sometimes quicker turning) and more stability - particularly in sand!
I have an e-axle on my 450F and can change my effective offset between 21 and 25mm. I also take care to preserve fork (front ride) height with e-axle adjustments. On my pit bike I changed triple clamps from 37 to 27mm offset and the effect was very obvious.
Stability depends on lots of things. eg. for me, when accelerating, too slow on fork rebound or too fast/soft on fork comp and I can get head shake. Lucky for me what works best for turns gives me little to no headshake.
Fitzy, if you like 22s on your berg, then with 19s you should feel the front tyre contact patch is too slow to respond and steer the front. So you would be able to lean the chassis but it wont begin to turn soon enough, and will tend to fall flat on the inside. Which is why earlier I mentioned ride height. Generally I've found that more trail (lower offset) helps flatter or off camber turns, and less trail helps with banked/bowl corners, and between the trees.
Edited by numroe
Just out of interest, what sort of fork height changes do you make when switching between different offset triple clamps to reserve front ride height?
The 22mm clamps make everything better on the Husabergs, it makes the bike more stable at high speeds and the steering is less aggressive while cornering.
The 22 mm triple clamps may improve some things, but I seriously doubt that high speed stability is one of them.
Went out tonight for a few laps and the soil was a bit fluffy? In other words the berms would not hold you as they would push out.
Discovered a few things though.
With original sag, 105mm, the forks at the second ring, I started at 18 0n the rebound and have ended up at 14, may go back to 15. This is a huge improvement, but I think a revalve might be in the works.
bike now turns a heap better but you have to be on your game if it decides to tuck,
If you get aggressive and put you weight out and forward, it makes a huge differance on this bike, seems very weight sensitive to me. I will leave it as it is for the time and get it back out in the bush on the weekend, as its a new ball game out there to an MX track. Looked back at a few photo's from the weekend and did notice that it uses nearly all of its suspension on the upramps and on landings but only remember it bottoming once and that was on an overjump and landing on the flat, so its pretty close for my offroad speed, nice and plush, just how I like it, for an old fart like me!! but may start firming it up and see how it responds
Will report back next week
Edited by fitzy
Fitzy, sorry about the temp thread hijack I'm about to do ...
I think I know what you mean, but I'm not changing the offset in the triples. I'm changing it in the axle. Look at the following drawing. I know this is a road bike but the forks are in front of the stem, so the principle is the same.
Take a look at the diagram below. If I change the offset via the axle, then the fork length typically changes too. So if I want to change just the offset and not the height, then sometimes I move the forks in the clamps. First time I put the e-axle in and tried it in a few diff positions I thought hey it feels like the sag is changing. Rekluse market it as a super quick adjust, and for sure it's quicker than changing triples! But for most adjustments you need move the forks a little too.
Interesting Rekluse say that less offset increases front wheel traction. I dont think of it that way. I think the offset is more about the timing between chassis lean and front steer. There is a sweet spot where the steering re-directs the front the right amount and also the chassis feels very top-light.
You go for it girlfriend!!! :ride:You make more sense than me!!!:banana:
:banana: ... :lol:
Hey, were in Aus are you doing your night riding?
  • Similar Content
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By hondahondo
      A few picks of my winter project.
    • By Luke Hufford
      Hey guys. I recently purchased a 16 yz250x and the first 2 rides i LOVED the suspension. Then the day before a race i reset all my clickers to stock and everything felt like crap. No plushness at all and deflected off everything. I now have a 5.4 shock spring for my 190 pound weight and dialed in sag. Any recommendations on where i should go from here? Right now the fork is 12 out on comp and 15 out on rebound. Shock is 1.75 turns out on hsc, 14 out on lsc, and 18 out on rebound. Any help would be appreciated!
    • By jake gu
      Today we’re going to be talking a little bit about automotive suspensions and how they work to smoothen the ride of your car. There are mainly three purposes of the automotive suspension system. First, they support the  weight of the vehicle. Second, they maintain accurate tire contact with the ground. And third, they absorb any shock that you get through the road when you hit a bump.
      Most modern vehicles come with an independent front suspension. Which means if one wheel hits a bump it does not disturb the other wheel. Nowadays, people use Coil Spring to support the majority of weight in the car. As it has a really good characteristics for absorbing any bumps as you go up and down on the road.
      However Springs aren’t very good at dissipating that energy. In fact that’s why you have the shock absorber. Which is there to smoothen out the ride and make sure the tire maintains contact with the road.
      In modern passenger vehicles the two most popular suspensions are McPherson strut and double wishbone style of suspension. The main advantage of the McPherson strut suspension is that it’s really cheap and simple that’s why a lot of manufacturers are moving towards this design. The double wishbone design allows the wheel to stay perpendicular to the body as it navigates a corner or as it goes over a bump. And that maintains good tire contact patch no matter where the wheel is situated. Another advantage of this design is that it can be made adjustable where you can control the position of upper control arms ball Joints.
      Click to Know More About Ball Joints and other Suspension Components
