big bore piston rings
I've been trying to find some rings (and gaskets) that will it on my Athena 440 big bore, but not luck. I've heard that other companies make rings for the kit but, I want some rings that will be as reliable as the ones I have on there now. Also, I have about 7000 miles on my big bore kit. Is there any other maintenance I should be worried about? My valves are in spec. Thanks for the help!
No smoke?
Runs good?
Ride it.
Lots of places to get the 94mm gaskets. You dont have to use Athena gaskets specifically. Not too many places to get the rings though. With that many miles already I would suggest to replace the piston also anyways when you feel its necessary but, no smoke and it runs well, just keep on truckin..
My $.02
